DIY polyurethane Engine Mounts
Old Sep 6, 2016 | 10:36 AM
Lvhrts82's Avatar
So I just purchased an 80A DIY polyurethane mounts insert kit (liquid epoxy) from energysuspensionparts.com. it will be here in 2 days ..I am going to document the entire process in photos and will be posting it when completed ...I have a question...Can I add polyurethane to the front and rear engine mounts??? I know they are hydrolic and have a vacuum port so , will adding polyurethane to the mount stop the mount from functioning properly???
Old Sep 6, 2016 | 10:41 AM
when ON accelerator, the stock mounts stiffen up due to vacuum port.
when off gas, mounts relax.
if you add polyurethane, it just wont stiffen up on acceleration because now it will be full stiff forever... you can then disconnect the vacuum lines from the mount and from the intake manifold
Old Sep 6, 2016 | 10:43 AM
Lvhrts82's Avatar
So I'll have to trade off having a more stable idle for stiffer mounts right??
Old Sep 6, 2016 | 10:48 AM
LOL!
if you're going to durometer of 80A, it's going to be stiff regardless.
maybe trade off isnt the correct term.
if you're going this route, means you've ALREADY considered your car is going to be a mini massage chair.
Old Sep 6, 2016 | 11:25 AM
Lvhrts82's Avatar
LOL!
I want to make performance upgrades and I know those measly rubber mounts aren't going to do justice ...
Old Sep 6, 2016 | 11:26 AM
are you ready for mini massage chairs?
Old Sep 6, 2016 | 11:40 AM
Lvhrts82's Avatar
In your opinion should I only do the passenger side mount ???
Old Sep 6, 2016 | 11:44 AM
I have 70A XLR8 aftermarket mounts; Front, Side, and Rear.
my opinion DOESNT matter, as all that counts is YOUR opinion...
Are you ready for mini massage chairs?
Old Sep 6, 2016 | 12:15 PM
Lvhrts82's Avatar
well I'm waiting on brand new mounts ....maybe I should try the poly on my existing mounts and if I don't like it I can always put in the new stock ones ...
Old Sep 6, 2016 | 12:26 PM
sounds like a plan, JUST IN CASE, you dont like it.
my car is my race car. I love it, vibrations and all.
Old Sep 6, 2016 | 03:28 PM
Lvhrts82's Avatar
I can't seem to find a DIY on applying the poly to vertical mounts ...only on rotational mounts ....happen to know where I can look ???
Old Sep 7, 2016 | 06:48 AM
never done a poly fill before. didnt know you could only do one type of mount.
Old Sep 7, 2016 | 08:08 AM
gavriil
Jan 6, 2025 01:04 PM
UA6andfriends
Jun 23, 2016 06:26 PM
OnlyDaanish
Mar 21, 2016 05:12 PM
