Custom lip kit
Old May 27, 2008 | 12:59 PM
rbsurfer's Avatar
Custom lip kit
I am pondering the thought of building my own lip kit out of fiberglass resin and sheets because buying an OEM kit is way too expensive
I want to use some of the ideas from across the board of lips in the past If anyone has sugestions on anything in my new little project pleas feel free to tell me thanks in advance
Old May 27, 2008 | 01:04 PM
phee's Avatar
I got the Shifts
wouldnt that be MORE expensive? i really like the 99 front lip more than the 02-03 and if you could incorporate the middle of the new aspec=secks
Old May 27, 2008 | 01:15 PM
rbsurfer's Avatar
i really want to make an extremely agressive front lip for the 02-03 because thats what I have
and it would not be at all expensive 15$ for the foam to create a basic mold and fiberglass sheets and resin 30$ for alot of it so not really expensive but alot cheeper than the 150 or so for the OEM front lip
Old May 27, 2008 | 01:40 PM
RusType-S's Avatar
Type-S
How do you creat it..............
is there like a company or something??????????
becouse i need to ceat a lincoln ls lip becouse i cant find it any wher so if you can please help me find any how to creat them ill br breat.....
and y fiberglass cant you use plastik?????
Old May 27, 2008 | 01:54 PM
rbsurfer's Avatar
fiberglass for one is the simplest thing to work with and you take the foam shape it with sand paper the lay the fiberglass sheets over it and pour resin on it and use a squeegie to smooth it out the it will harden then you just sand the pop it out of the foam and you have a fiberglass lip its quite simple
Old May 27, 2008 | 02:32 PM
RusType-S's Avatar
Type-S
I dont really get it but if you post some pics thats better so please post some pics so i can see how its done...
ok thanks.......
Old May 27, 2008 | 02:39 PM
fsttyms1's Avatar
Its not as easy as he made it sound. While its not "hard" its not that simple. It taks alot of work to get it smooth and strong. I personally wouldnt buy or build a body kit from fiberglass. Its way to prone to cracking.
Old May 27, 2008 | 03:41 PM
jjashaa's Avatar
Avant Garde Wheels
Old May 27, 2008 | 09:15 PM
BlackuraTL's Avatar
Broke college grad
Word x2 where you live surfer?
Old May 28, 2008 | 08:37 AM
co1063's Avatar
he lives in DE, right? if it turns out well, make me one too!
Old May 28, 2008 | 01:23 PM
rbsurfer's Avatar
yep i am a de boy. where in de are you co1063. thats why i wanna make it if I do i can reproduce it as many time as I want so if it does crack i can just take it off and put another one on
Old May 28, 2008 | 01:25 PM
rbsurfer's Avatar
i am in the beach area like lewes and rehoboth area
Old May 28, 2008 | 01:37 PM
heyitsvu's Avatar
OM NOM NOM NOM
I guess it's really up to you. you have to think of the time/cost for it because obviously, it will take up a lot of your time to make the lip. is it worth the oppurtunity cost of making t?he lip yourself as compared to buying an oem front lip (sorry my econ is kicking in)? will the quality be good? i heard fiberglass is shit. it'll break with any instance of hitting something, and i know because my brother's kit broke so many times on his legend that he got pissed and went out and spent a lot more on a polyurethane kit. think about the long run and the time it'll take you to make/remake the kit and maybe you might decide otherwise. you'll save yourself 50 bucks now, but after making the kit again 3 times, you're way better off when it's just the paint rubbing off of the bottom side of the lip as compared to the fiberglass breaking apart.
Old May 28, 2008 | 01:44 PM
rbsurfer's Avatar
i mean yea you got a point but and really good one its just the fact of i like to make stuff and i do have alot of time so maybe i will learn how to use poly ur. and produce it in poly ur. so its a good start.
Old May 28, 2008 | 02:13 PM
LIPPSTUH's Avatar
Unregistered user
only problem with that is that its not cost effective
painting a lip costs around $150 each, unless you want shitty paint.
not worth it imo
Old May 28, 2008 | 03:42 PM
co1063's Avatar
wilmington, but i need a 99-01 front lip.
Old May 28, 2008 | 03:47 PM
heyitsvu's Avatar
OM NOM NOM NOM
^ with Lippstuh
also, to your last response surfer. PolyU is not cheap. a 1/8 inch thick 24"x58" sheet of polyurethane is about a hundred dollars not including shipping. if you want 3/16 which is what i think our cars are, it's going to cost you about 125, and 1/4 is 150. this is not including the fact that you have to mold it to specific pieces. you're looking at paying maybe 250 for supplies not including what you need to actually mold the parts to your liking. I'm sure you can do the math from here. Learning how to use polyurethane is one thing, actually producing a masterpiece is another. If you screw up, it'll either
1. look ugly
2. be deformed
either way will cost you money. I'm not trying to discourage you, but it doesnt sound like a good idea. I'd rather have acura send me one then waste my precious time and money on something I don't know will even come out correctly.
TLrascal
Aug 3, 2018 11:00 PM
BoricuaTL
Apr 8, 2016 01:08 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Sep 17, 2015 08:57 PM
Sep 4, 2015 08:03 AM
