crank pulley bolt starter method inquiry
hello there all ... if my crank pulley bolt will not come loose with proper tools & human strength (no air gun) i am willing to use the starter method. my question is how do i /can i disable the ignition system?
well .... if some of you advise against it, due to possible motor damage, then actually i'd rather not. i'm thinking can't get it loose - head over to truck stop that will have a 1" impact gun and compressor & hopefully bribe em with a 20 spot
You don't have to disable the Ignition.. Just pull the Fuel Pump Fuse and there you go! Engine wont start unless you WOT it but that's the point you just need to undo the bolt so a single turn of the key will do... or you can also do it the hard way and unplug each and every COIL packs..
If you have your doubts, try it. I can assure you the engine wont start it will just crank... Only way to start it, its to fully WOT and the engine will stall the moment you let the gas off but that's irrelevant for what you need to do.
Nope, I believe this has been done several times over the course of years in millions of cars... Its the Guetto Style Crank Bolt removal Procedure.
Just what-ever you do try it before proceeding, You don't want your engine to start with a pry bar attached to the Crank Bolt.
DONT turn the key and hold it like you are trying to start it. Just a QUICK turn key to Crank then turn back to stop like 1 second or less blast. Again, DONT hold the ignition like you are trying to star it.
And no, you wont get engine damage from doing it.
So much easier to go to a garage and have them hit it with the 1" air gun.
Just be super sure they have it set to loosen. A 1" gun can easily shear the bolt clean off.
Once broken loose they can snug it down to get you home for final removal.
We broke a 3/4" impact trying to do the tb on my TL. Took it to my dad's friend's shop & he put the breaker bar against the frame/front tow hook & was able to really lean on the 2nd wrench then without worrying about it slipping.
^what I did with 1/2" drive. So much flex in our extension here it scared me.
The only thing harder to remove on our cars (from what I've done) is that axle nut, broke a 1/2" drive ratchet and needed to use a 3/4" drive breaker bar. THAT SHIT HANDLES.
imho, all these methods a waste of time. starter method extremely easy 30 seconds or less you're done. no damage to anything. starter method way way easier & straight forward than anything else & as far as i know has a 100% success rate. done on thousands of cars every year. something must be right about it!
I went with the extension+5ft cheater bar method. I had more than 45 degrees of flex until the bolt came loose. Thought I snapped something until I realized it worked. Never tried the starter method, not that it was possible to start my car anyways since I had the IM out already.
Jul 16, 2017 07:33 AM
