Coolant leak
Old Jan 11, 2010 | 12:57 AM
Bricktop's Avatar
Coolant leak
Hello,
I found this little pool of coolant on the engine, but i can't see where it is leaking from. It's right behind the rear cylinder head.
Hope it's not serious.
Thanks for your time..
Old Jan 11, 2010 | 04:29 AM
Rajca's Avatar
wham bam thank you ma'am
have u taken ur intake off or ur throttle body off recently?
Old Jan 11, 2010 | 05:31 AM
01tl4tl's Avatar
has to be the coolant bypass lines to the TB
Ck clamps, ck for worn out hoses--if they are soft they are worn out
See DIY thread on Thermoblock spacer install- it has good pics of the manifold hoses and the hidden locations
You can attach a `pressure tester`- free loaner tool from parts store- apply running pressure to radiator and watch where fluid comes out
Old Jan 11, 2010 | 11:07 AM
Bricktop's Avatar
I haven't messed with those....
Old Jan 11, 2010 | 11:13 AM
Bricktop's Avatar
Weather permitting, i'll take a closer look. It's just so cold outside
Old Jan 11, 2010 | 12:01 PM
fsttyms1's Avatar
Has the car been in for service in the past month or so? What is your coolant level like?
Old Jan 11, 2010 | 12:29 PM
Bricktop's Avatar
There's coolant in the bottle, but i can't see where the level is exactly.
The level in the radiator is up to the filler neck.
Old Jan 11, 2010 | 03:18 PM
01tl4tl's Avatar
the res bottle is an important tell
It needs to be at the cold full mark when checked- overnight cold
AND the rubber hose attached inside the cap must be in place- it likes to fall off into the bottle,,then no transfer can occur and you get problems
Pressure test the system and the leak should be obvious- its in a strange place to find coolant and not much there but the small hoses to the TB..
Old Jan 16, 2010 | 12:42 PM
Bricktop's Avatar
The transmission was replaced by acura back in march 2009.
Old Jan 16, 2010 | 12:50 PM
Bricktop's Avatar
The weather was nice today, using a mirror i found traces of coolant coming from the rear mounting bolt of the thermostat housing.
Old Jan 16, 2010 | 03:01 PM
01tl4tl's Avatar
thats odd but things do come loose
Try tightening it for now but if its leaking its getting past a gasket seal that needs replacement
Old Jan 16, 2010 | 03:30 PM
ChucksCL-S's Avatar
Use a flashlight to check the bottle, it is white plastic and is next to the driver's side headlight. You have to dig to see the level, it is marked COLD and HOT I think.
Old Aug 27, 2023 | 05:41 AM
Carl817's Avatar
What is this hose called I have a leak from it
[/QUOTE]
Old Aug 27, 2023 | 01:45 PM
Does it look like one of the two circled in red?
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
