Concerns!
Concerns!
hey guys i have some concerns with my new TL. (stock)
1)I was wondering if my 2000 TL is suppose to be big on gas..how far can u guys with a full tank..im canadian..how much should i be able to go (km's) with a full/half tank.
2)Second, my engine seems to heat up alot while i drive...no light comes up on my dash board but i sometimes can feel the heat while i drive..i was thinking about getting a cold air intake..but just wanted to ask some ppl why this might be happening..its not hot hot, but it hotter than other cars i see..
if ppl can help me with this, it would be soo helpful thank you
And I really don't understand what you're talking about with the engine running hot. Is your temperture gauge rising? If it's hot in the cabin - turn on the air conditioner?? I'm kind of a noob, but I'm pretty sure a cold air intake will have nothing to do with how hot or cold your engine runs.
What are you used to normally driving? You've got a bigger engine up front.
Cant say I feel the heat while I am drving, lol... And mine is about normal to other cars.
My temp needle is normally at one or two needle widths below half, and we have some hot days here in FL and it never goes about that.
Also I average about 22-24mpg city and about 30 all highway.
messing around ill get 250 to a tank, driving normal..under 3k rpms... around 350
dunno about the heat thing, if the gauge is no above halfway your good, another thing, even if you ac/heat is of, make sure you put it to a cooler temp, ive noticed the heat thing too, mainly because my climate control was set at 90 then i turned it off, got hot, so i turned it back on and set it to 60 then turned it off again, stopped blowing hotter air, i dunno shut up
Just filled my '02 up....about 3mi after the light came on...it sucked 12.25 gallons of 93 oct....got 332 miles out of it at 25mpg on 50/50 hwy city driving.....did get 30mpg on a trip down to Miami last week, all hwy.
How big is our fuel tank???
I did a lot of highway driving in the last month and I got 609 kms and the gas light was on. When I'm driving in the city I get about 370kms to 450kms depending on how hard I drive it.
I also fill the tank right up, after the pump auto shuts off ....I can continue to put in quite a few more litres as long as I fill slowly.
OK, with the heat... Try pushing that button on your deck that looks like an arrow pointing out of the car, or kind of circling from out of the car, Push that and the light will come on, that basically stops the Vented Air from comming in, other than that. i cant tell you.
So with a 17 gallon tank, when the fuel light goes on the is still about 5 gallons left in the tank??? That sounds like a lot of reserve fuel....over 100 miles worth of driving with the light on?
My99acuraTL
IllTL,
you should be getting something close to 12 litres/100km or (20MPA) depending on your dirving habits
so a fillup of 15gallons (56litres) should go for about ~470 km or ~300 miles.
check out your radiator for the heat, as long as the needle is satying below half gage you are ok. does the fan go off once in a while to cool off the radiator??
I can normally get anywhere between 450-550kms until the light turns on depending on how I drive of course. Maybe it was just me but I got better fuel economy when using shell 91 rather than sunoco 93.
As far as the heat is concerned I notice the same thing on my car. My temp needle is below the half way mark but the car definately feels different... but I dont think its anything to worry about.
Originally Posted by 03CoupeV6
When my light comes on, I can put in 14 gallons, not 12. When it reads E there are about 3 gallons left. At least that seems to be the generally accepted information.
I average about 25mpg driving normally (60 city/40 freeway), I get about 21mpg driving hard, about 320 miles for 15 gallons. 100% freeway gets me a little over 30mpg.
Originally Posted by kelhasna
IllTL,
Ok guys i will fill it up and see. Im new to a big engine so i guess i have to get used to it. i will check the radiator..but my dad said its common.
*the fan does go off once in awhile to cool it down and my needle is about 2-3 clicks down from half..so its alright.ill look into it..
THANKS EVERYONE FOR AWSOME HELP..THANKS.
as for the mileage. just like the others have said. its a 17 gallon tank, when the light comes on there are aprox 3 gallons left
oo7spy
Technology
26
09-22-2015 10:01 AM
