clock light is Out
Old Jul 14, 2002 | 02:19 PM
KJ32's Avatar
clock light is Out
I just noticed the back light of the clock is OUT. It wouldn't come on when I turned on the low beam. Checked #9 fuse on the driver side fuse box, the fuse is good. Check serveral other fuses under the hood. Everything is fine. Anyone has the same problem? Does anyone know what other number fuse I can check? I really don't want the dealer touch it if the bulb is out because they need to remove the whole front panel to gain access to the clock unit. Please help!!!!
Old Jul 14, 2002 | 03:56 PM
randomwalk101's Avatar
Sounds like the bulb behind it is out...all you have to do is remove the panel and pop the connect then remove the clock assembly. You can use the small screw driver to take the light out and replace it.
Old Jul 14, 2002 | 04:00 PM
KJ32's Avatar
It's a pretty big job, isn't it? I look in the service manual, there are many items to remove before getting to the clock. Am I right?
Old Jul 14, 2002 | 05:29 PM
KJ32's Avatar
Anyone experiencing the same thing? I wonder if I can just change the bulb or the clock unit. That determines if I want to do it myself or let the dealer handles it.
Old Jul 14, 2002 | 06:33 PM
njzprettyboy's Avatar
i had the same prob......take it to dealer they will fix if its under warranty
Old Jul 14, 2002 | 07:00 PM
KJ32's Avatar
Could oyu please tell me what exactly did they do to fix it? I really don't want them to take apart everything for that little light bulb. Thank you for your reply.
Old Jul 14, 2002 | 07:28 PM
aMiR_RENAMED's Avatar
mine is out too except some of it comes on and part of the lcd don't show...... Can you buy the clock from the dealer and how much does it run? Is it easy to change?
Old Jul 14, 2002 | 08:31 PM
djalliance's Avatar
Had the same problem...It was under warranty. I went there first thing in the morning and I was out in 15 minutes...Sorry, I never asked what they did. Everything is fine now.
Old Jul 14, 2002 | 08:41 PM
STANLEY TORONTO's Avatar
same here, my clock light is out also, but I hit it two or three times, then it will come back ! . But if you didn't put any mods in your car, why you don't just take it back to your dealer and fixe it? cos it is under warranty, and no charge, but you seen worry the dealer wil do something bad on your car huh? Anyway try to give it a hit, maybe the light will come out agaiN ~
Old Jul 14, 2002 | 09:10 PM
KJ32's Avatar
You sure hit it nicely Stanley. I tried tapping on it, but that didn't work. My guess is either the bulb is blown or loose. The reason I am hesitated to bring it back because they screw up more thing than fixing that little thing. If they need to pry open the instrument panel to reach the clock, most likely I will see many scratches on the panel. Then I will have to haggle for a replacement. You guys probably think I'm A-hole.
djalliance
What dealer did you go to? They never told you what they replaced? Thanks.
Old Jul 15, 2002 | 08:56 AM
djalliance's Avatar
KJ32
I went to Springfield Acura in NJ. They didn't tell me and I didn't ask what they did to fix the clock. Sorry...
Old Jul 15, 2002 | 10:09 AM
I go to North York one in Toronto, but you seen like live in US. Anyway you can bring your baby to some car stores, at least you trust them
Old Jul 15, 2002 | 08:15 PM
KJ32's Avatar
Unfortunately, my ride is under warranty and there's no way I dip into my own pocket for their lousy part.
Old Jul 15, 2002 | 08:27 PM
sssick's Avatar
If youre that concerned about them scratching the panels take a picture that has a date on it so if they do damage it you have proof. Whats the point of having a car with a warranty if you are afraid to use. Face it the only one thats gona treat your car good is YOU. So anytime someone else is in possesion of your vehicle without you present they are going to take it for a "spin".
Yikes
May 3, 2021 04:29 PM
95legend6speed
Sep 21, 2015 06:40 PM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
