Clock fuse
Old Mar 19, 2009 | 11:55 PM
Eddystone's Avatar
Clock fuse
So I just changed my rear oxygen sensor, should I reset the ECU by pulling out the CLOCK fuse #13 on passenger side ?
If so do I just unplug it and wait 1-2 minutes then plug it back ? I am not a mechanic so I am scared of everything that I dont know.
Old Mar 20, 2009 | 06:05 AM
fsttyms1's Avatar
Yes. Unplug it wait a min then put it back in.
Old Mar 20, 2009 | 12:35 PM
Eddystone's Avatar
When is it recommended to that ? like after changing parts, what parts ?
Old Mar 20, 2009 | 03:34 PM
fsttyms1's Avatar
any time you fix something that has caused the CEL light to come on
Old Mar 20, 2009 | 08:44 PM
Eddystone's Avatar
Whats the purpose of doing this ?
Old Mar 20, 2009 | 10:38 PM
nayaab88's Avatar
I'm guessing so the ECU will relearn whatever it has to relearn after you put your new parts on.
Old Mar 20, 2009 | 11:47 PM
Eddystone's Avatar
I just did the reset and it seems "alittle" better.
Old Mar 21, 2009 | 12:51 AM
wdptls88's Avatar
My guess is to let the ECU have time to re-learn the system.
Old Mar 21, 2009 | 11:44 AM
01tl4tl's Avatar
Pulling the clock fuse- which is the secret backup power source for the ECU Engine computer, will force a reboot and relearn- and will self test all the systems
Similar idea to what happens if you turn a PC off with the power switch
Acura604
20
Aug 5, 2017 12:55 AM
Skirmich
Oct 1, 2015 12:59 PM
ripit
Sep 26, 2015 06:19 PM
2Quik
Sep 23, 2015 01:03 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
