cleaning the plastic lens of front headlights
Old Dec 9, 2004 | 08:19 AM
joseph_99tl's Avatar
the outer lenses on my headlights are all pocked up.
and hazy...and very roughed up.
can this be fixed.
Old Dec 9, 2004 | 08:29 AM
SK2003TypeS's Avatar
yes, it can be fixed....or at the very least, worked on to make it look better. It's hard to say without knowing what it looks like.
You may need to clay it or clean it with a plastic product like Plexus. I wash my car every week, so I haven't run into this yet.
maybe move this over to the W&W forum ?
Old Dec 9, 2004 | 08:30 AM
sc354's Avatar
can this be fixed.
I know that meguiar's has a cleaner specifically for plastic surfaces. Our headlight housings are made of lexan, so it is safe to use it on them.
Personally I have never used this product, but I hear it works really well. Your headlight housings should look brand new once you're done with them.
Here is a link to what product you need.
http://www.properautocare.com/meplplclpo.html
you don't have to buy from them, I'm just showing you what product you need to cure your problem.
Hope this helps.
Take care.
Old Dec 9, 2004 | 09:09 AM
fsttyms1's Avatar
the meguiars line works really well ive used it for years
PlastX Clear Plastic Cleaner & Polish http://www.meguiars.com/store_meguia...&subcatagory=1
Old Dec 9, 2004 | 09:13 AM
SMILEY's Avatar
TLS - The Lust Sedan
I did these steps to my 96 Sebring and the results were amazing.
Parts
800 grit wetordry sandpaper
1000 grit wetordry sandpaper
1500 grit wetordry sanepaper
2000 grit wetordry sandpaper
3m Rubbing Compound
Some type of carnuba wax
Bucket of cool clean water
This is very simple.
1. Soak the 800 grit sandpaper and goto town on your headlight. Keep sanding, once you think your done sand some more, a good rule of thumb is first grit paper sand for about 10min on the whole lense.
2. Dry off the light. and move onto the 1000 grit, Soak that and sand for about 20mins(noticing a patteren here) Continue this with 1500 and 2000 grit papers doubling your time with each grade of paper so basically
800 - 10min
1000 - 20min
1500 - 40min
2000 - 60min
3. Once you've finished sanding the lenses, their going to look very dull,hazy,scratched up. This is what the rubbing compound is for. SImply follow the directions on the bottle for applying and removing and repete this step about 2-3 times.
4. Take whatever wax you use on your car(I'm a meguiars person) and wax your headlight like you would your car. and BAM! your lights should look like the day your bought the car.
4b. It would also help to wax your lights everytime you wax your car, just to keep them protected since this isn't exactly a short process.
Old Dec 9, 2004 | 09:39 AM
thx, Smiley.
thats a project alright
i'm gonnal try the plastx first.
Old Dec 9, 2004 | 09:48 AM
SMILEY's Avatar
I actually cut the time in half and still got the great results.
Old Dec 9, 2004 | 10:19 AM
https://acurazine.com/forums/showthread.php?t=163090
Old Dec 9, 2004 | 10:43 AM
TeknoKing's Avatar
you guys think stuff like that work?
http://detailking.goemerchant7.com/i...ExpandedDepts=
Old Dec 9, 2004 | 10:44 AM
TeknoKing's Avatar
or this http://www.lensrenew.com/ ?
Old Dec 9, 2004 | 11:40 AM
reloaded's Avatar
WDP Is Faster
would these products work on the RSX taillights? I was redding out my bro's RSX and I kinda cutted it up.
TLrascal
Aug 3, 2018 11:00 PM
scionxb3003
Oct 2, 2015 05:50 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
JnC
Sep 11, 2015 06:06 AM
08 NBP TL
Sep 8, 2015 08:49 PM
