Cleaning Exhaust.
Cleaning Exhaust.
Hey guys, I seafoamed my car in the summer but my tl friends say that i need to clean out my exhaust. How do i do that and will it make a big difference? my engine runs nice though after seafoam.
correct me if i'm wrong, but as i understand it, you can clean your egr system by removing the silver plate on top of the intake manifold, and then spraying a throttle body cleaner (and then i used an old tooth brush) into the small passages under the plate. i would advise removing the entire manifold to do this tho.
you MUST remove the intake manifold if you expect to get any cleaning of the EGR ports done
see the DIY-- it needs to be done about every 75kmiles, per a megamod with 300kmiles on his TL!!
The exhaust cleaning your friend spoke of is actually done by ---lets all say it together- SEAFOAM
read the can or website for info www.seafoamsales.com
it clean the carbon loading all the way from intake thru tailpipe
Suggest seafoam 1st timers repeat vac and gas method after 2000 miles then good for a year
To clean exhaust throw 1 can in 1/2 tank of gas
