Check Engine Light Code
My 99TL check engine light is on and I scanned it with the AutoXray 6000 scanner. The result is "P0401 - Exhaust Gas Recirculation Flow Insufficient Detected".
Reset it and then the next day it came on again. Scanned it again, same result.
Does anybody have the same problem?
Is it an easy fix?
Is it an easy fix?
ChairmanMaoSaysRTFM
Is it an easy fix?
Is it an easy fix?
SSTS
4th Gear
Check with the dealer first if it's covered under any warranty, there was a service bulletin for this code to clear the egr passage in the intake and install a new valve for this code
its a easy fix i just had a post on this not but a week or so ago. 3 cans of carb cleaner will fix the problem.
oh and the dealer wants 400+$$ to fix the problem, it cost me 6$$ to fix it and 1 hr or so of my time to do it, and you wont be covered under warranty to do it!
scroll down to post #4 http://www.acura-tl.com/forums/showthread.php?t=89622
to fix the problem properly you have to remove the intake manifold(sounds a lot harder than it really is) drill out the egr passage with a special drill bit and insert a sleeve. also replace the egr valve. the carb spray will work but not indefinitly.
HeloDown
09-08-2015 06:51 PM
