check engine light
Old Feb 17, 2011 | 11:16 PM
NJoba147's Avatar
check engine light
on my drive home tonight my check engine light when on :thumbsdow. so tomorrow i gotta check it out. its never happened before so i'm hoping its nothing bad...
Old Feb 17, 2011 | 11:19 PM
01tl4tl's Avatar
cel,,not just the Mait Req light right?
stop by a parts store for a free code reading
Car doing anything funny? idle not smooth as usual?
car miles?
Old Feb 17, 2011 | 11:34 PM
NJoba147's Avatar
i know its not the mait req light i've had that a few times. it just hit 120,000 but sometimes it seems like it has trouble starting up but i just assumed that's the 19 degree weather.
Old Feb 18, 2011 | 07:25 AM
RC99TL's Avatar
my guess is: EGR insufficient lift.
Time to clean that port!
Old Feb 18, 2011 | 07:31 AM
Mr. Maker's Avatar
Get some mud guards.....cleared my cel....
Old Feb 18, 2011 | 08:50 AM
NJoba147's Avatar
yea i dont know much about this stuff, so i have no clue what you guys just said hahah
Old Feb 18, 2011 | 09:00 AM
RC99TL's Avatar
When you get the code read in my bet is it will indicate the egr port is clogged.
The codes that come up usually are: egr, insufficient lift or catalytic converter below threshold. Keep in mind codes are only clues and if these codes come up like I said earlier chances are the little passage in the upper intake manifold is clogged. Our TL's clog the egr port easily as it is a very small passageway. Also if your car does not have the update to move the pcv port away from the egr port it will clog faster due to the oil vented into the intake.
Old Feb 18, 2011 | 11:27 AM
NJoba147's Avatar
alright thank you
Old Feb 18, 2011 | 08:25 PM
RC99TL's Avatar
let us know what you find
Old Feb 18, 2011 | 11:23 PM
NJoba147's Avatar
the code came up as P1457-Evaporative Emission Control System Leak Detected(Control Canister System)
Old Feb 19, 2011 | 09:55 AM
RC99TL's Avatar
Check your gas cap. It may be loose.
Old Feb 19, 2011 | 07:06 PM
Karanx7's Avatar
Unregistered Member
Lol, my car used to pop random CELs with the TCS light. Usually said something about 3rd gear transmission clutch pack. Popped a few others about some solenoid. After resetting it a couple times, they haven't come back in 20k. I never had any problems shifting or anything, so I'm thinking it may have been electrical.
Old Feb 19, 2011 | 07:35 PM
Skirmich's Avatar
Not to steal the thread just a Question! if my Car hasnt clogged the EGR port now with 179K am I safe or I could do a Preventive cleaning? And if so! Do I have to buy new gaskets or they are all Aluminium reusable type? Thanks for any Replys!
Old Feb 19, 2011 | 07:50 PM
01tl4tl's Avatar
you are wayyyyy overdue and will find lots of carbon to clean out of the ports and passageway
see the diy, can reuse gaskets if careful
but I would get a TB to manifold just in case it tears, and a new iacv cover gasket
Old Feb 19, 2011 | 07:51 PM
01tl4tl's Avatar
note 99s have 1 egr port into the manifold
while 00 and later have 6!! so be sure to get all of them~
Old Feb 19, 2011 | 09:37 PM
Skirmich's Avatar
OK then just the TB Gasket and the IACV! Got it! Ill have a trip to my Honda dealer Monday Morning to buy them and see if I can do it next weekend!
No Manifold gasket right? just to be sure!
And It didnt help that I run Seafoam every oil change in the Manifold?
Old Feb 20, 2011 | 11:23 AM
01tl4tl's Avatar
clarify- you run seafoam in the intake manifold- at oil change time?
not in the oil itself?
thats doing great for intake but...
the exhaust gas is what gets some of it sent back thru the egr- to be reburned in combustion chamber (cylinders)
while a very small amount of seafoam may be present its not enough
just make sure the top cover gasket gets set on the workbench the way it came off- can be installed upside down- which makes car run very funny!!
not much you can do except wait till its built up and scrape off
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
