check engine light ?
Press both of the buttons for the trip select and trip reset and keep them pressed. Turn the engine on and wait untill the flashing of the light in question stops. Once it does, your problem is gone. But make sure you do everything right, it says check engine for a reason.
PM or email me if you have any more trouble.
yes ther is a way, you can pull a fuse on the passenger side fuse box i forgot which one it is off the top of my head though.
Tristate Vip Crew
Originally Posted by jleon2516
Ok cool, do you know if I will need the radio code after I do this. I must have misplaced the radio code somewhere and cant find it. I really dont want to pull apart half the dash again to get the serial number in order to get the code. Thanks
For a group of people who are Internet aware enough to find this site, you'd think everyone here would register at Acura.com.
Tristate Vip Crew
Originally Posted by MikePA
Register your VIN at the Owners Link at Acura.com and you never have to worry about losing/forgetting your radio code or your NAVI code (if so equipped). You'll also never have to wonder what re-calls or extended warranties apply to your car. A heck of a lot easier than pulling half your dash apart.
My car is registered at acura.com, but I never put the radio code in there.
Last thing i want is for someone to have access to my radio code online, especailly with all the computer hackers out there.
Tristate Vip Crew
Have fun taking apart your dash....again. You could also visit your dealer and with your VIN, I believe they can tell you your radio code.
There are a lot better hacker targets on the Internet than Acura.com looking for the radio codes that might be there. If you are that paranoid about it, simply add one to each digit of the code, 1434 becomes 2545, or some other encryption code that you'll remember.
hey, jleon2516 why is your cel on anyway? what code?
do you have the indash cd changer, if so you can access the serial # without taking the dash apart, actualy you don't have to take the dash apart for any of them if you know were to look.
You can pull the "Back Up" Fuse located in the passenger side fuse/relay box for 10 seconds. When I reset my PCM, it did not do anything with my radio. I'm sorry that I don't remember which fuse # it was but there's a chart inside the fuse/relay box door.
Although there is a sticker that was either installed by the factory or dealer that lists my code for the factory radio.
Rob in Nashvegas
Rob in Nashvegas
Tristate Vip Crew
Tristate Vip Crew
Rob in Nashvegas
Rob in Nashvegas
Tristate Vip Crew
O, p0505 you didn't tell me if you had the in dash changer cause i could show you how to get the serial # and get get you code for you and pm it to you.
Theres a plug under your deck hiding behind a plastic plate u can remove and u can plug in that computer thingy and you can turn it off . Dont know what the computer is called thouhg
HeloDown
09-08-2015 06:51 PM
