CD changer Error E1
Old May 6, 2001 | 06:58 PM
Post CD changer Error E1
Has anyone had that problem on their Cd changer on th TL-S? I pressed on the EKECT button and suddenly it say Er-E1.
How can I fix that without bringing it to the dealer?
Old May 7, 2001 | 08:11 AM
thephantom's Avatar
Post
First, wip out the manual for the CD player and find out what that error means. THere is a list of error codes for the CD player. If you can't rectify the problem yourslef, I would take it back to the dealer because it is still under warranty. Good luck.
Those who know, don't talk.
Old May 7, 2001 | 08:30 PM
Guest
Guest
Posts: n/a
Post
I had this problem. It seems that I used my own CD with labels and tried ejecting, the CD began to peel at the edge and got stuck coming out.
I simple tried to grip the exposed CD at the opening and pulled it out. Part of ther CD label ripped as it came out.
Warning: Do not use CD with stomped custom labels. They will heat up in the CD player and loosen up. When you eject the CD the label will peel and stick or jam.
Good luck trying to get the CD it out.
Old May 7, 2001 | 08:33 PM
Guest
Guest
Posts: n/a
Post
Old May 16, 2001 | 05:24 PM
Post
Well, my dealer will change the whole unit next wednesday and will change the Window RECALL at the same time.
It's sad that only because the CD changer is blocked (can't eject), they have to change the whole unit.
Old May 16, 2001 | 08:18 PM
Guest
Guest
Posts: n/a
Post
[/B][/QUOTE]
Do you make your own CD's and stick labels on them. If you do - don't do it again or you will be changing your CD unit on a regular basis!
Old May 16, 2001 | 08:34 PM
imax's Avatar
Exclamation
[/B]Do you make your own CD's and stick labels on them. If you do - don't do it again or you will be changing your CD unit on a regular basis![/B]
Any you'll be paying to have it done. If it's damaged by a CD label and the dealer sees this it will not be covered under warranty!
'02 Acura TL-S
Satin Silver/Ebony, w/out NAV
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by imax on May 16, 2001 @ ]</font>
Old May 17, 2001 | 06:31 AM
Post
Originally posted by imax:
Do you make your own CD's and stick labels on them. If you do - don't do it again or you will be changing your CD unit on a regular basis![/b]
[/B]
No, I put a CD recordable inside but with no label on it. So it is ike a regular CD, right?
Old May 17, 2001 | 09:00 AM
Guest
Guest
Posts: n/a
Post
Yes.
phillyguerrilla
Sep 26, 2015 11:27 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Sep 21, 2015 08:44 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
