Cant start the CAR!!!!!
Old Nov 26, 2006 | 11:35 PM
wasup1357's Avatar
00 TL
Hi, I just came back from the thanksgiving holiday and try to start my 00 TL, when i turn my key in the ignition, I am able to turn on the radio and the battery, but it gets stuck when im trying to ignite the engine (the last "crank"). Anyone know whats the cause and how to fix it?? thz im a noob
Old Nov 27, 2006 | 12:51 AM
senvro's Avatar
possible ignition fuse??
Old Nov 27, 2006 | 07:20 AM
Luke7's Avatar
WNC Real Estate Sales99TL
It gets Stuck? WHAT? = the engine just won't crank? The key gets stuck?
Old Nov 27, 2006 | 11:48 AM
oVerBoost's Avatar
HELP!
if the key wont move to the last position, make sure your steering wheel is straight. hold it in position and try turning the key again.
Old Nov 27, 2006 | 12:30 PM
PenancE's Avatar
its ur wheel noob, its child locked
Old Nov 27, 2006 | 01:01 PM
RevinV12s's Avatar
Fallen
Also, Make sure the gear is at "P" - Park. The car wont start unless the gear is in P or N.
Old Nov 27, 2006 | 02:14 PM
fsttyms1's Avatar
It wouldnt even let you get to the radio positon if it was in the locked position.
Old Nov 27, 2006 | 02:46 PM
Final's Avatar
Opium den in
Yup... LOL did you call him a noob? Hahaha
Old Nov 27, 2006 | 04:43 PM
acutee's Avatar
check the battery connection, or get a jump start.
Old Nov 29, 2006 | 01:21 AM
wasup1357's Avatar
00 TL
the key doesnt get stuck, i just cant get turn it to the start the engine, the radio and the lights and stuff works fine.
Old Nov 29, 2006 | 07:34 AM
Turn your steering wheel to the right while turning the key..the your steer wheel is locked
Old Nov 29, 2006 | 10:08 AM
fsttyms1's Avatar
will it go to the start position at all or it just stops before hand? make sure that its going all teh way or not. then let us know
Old Nov 29, 2006 | 10:45 AM
joe80055's Avatar
Mine does.. if the wheel's locked, the auxiliary accessories are able to work.
Old Nov 29, 2006 | 10:58 AM
fsttyms1's Avatar
Then id say your wheel isn't locked. If its locked that key is not supposed to turn at all. Once you move the wheel the slightest but then the key is allowed to turn to all the positions
Old Nov 29, 2006 | 11:35 PM
wasup1357's Avatar
00 TL
well i can go to start position, just cant start the car
Old Nov 30, 2006 | 08:51 AM
fsttyms1's Avatar
no clicking to cranking or anything? Make sure the battery is good. If not id say its possibly the starter or starter solenoid.
Old Nov 30, 2006 | 08:55 AM
visuelz's Avatar
East Coast Crew
Try pumping on the accelerator with your foot a few times
Old Nov 30, 2006 | 01:17 PM
type-s09's Avatar
13.2@ 107 on Street tires
pumping the gas wont do nething considering its EFI
Old Dec 2, 2006 | 08:37 AM
jayunsplanet's Avatar
Key locked in ignition won't turn Batt OK HELP!
  • Went out to start my car this morning. It's about ~40F.
  • The key goes in, but WILL NOT turn anything.
  • Battery is ok, all lights work.
  • Releasing the foot E brake does nothing. Car does not move at all.
  • We unlocked the transmission (by sticking the key in the little cutout to the right of the shifter.)
    • As a result, the car rolled back 6 inches and is now wedged up against the curb.
    • Steering wheel is also locked.
  • This happened once before, and I just tried the key 3 or 4 times while pumping the break.
ANY help is immensly appreciated.
Of course, I have a car show to go to at 10:15...
Old Dec 2, 2006 | 08:38 AM
Sorry, I accidently posted a "Reply" instead of a "New Thread"
The thread is here...
https://acurazine.com/forums/showthread.php?p=1601721
Old Dec 3, 2006 | 09:43 AM
S1CK TypeS's Avatar
B A N N E D
check ur ignition wires mine somehow got disconnected
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
