can someone explain the whole mystery mod thing to me
Hey I have a 2001 tl and i was wondering what this mystery mod that people are talking about is, what it does and where i can get is. also will it work for my tl. thanx alot
I believe the mod is a replacement for the resonator, which is the gray rectangle with the chrome nuts on the plastic engine cover. It is supposed to help with the airflow passing through the intake manifold when it gets to above the engine. Supposedly it helps increase horses all across the RPM band.
what ever you do,donot do a search on mystery mod or MM,i think tims server would be brought down from the strain...there's plenty of topics on it in the last 5 days
Retired MOD
1 Post
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Here you go: Posted by doug.
RES or Resonant Enhancement System is what the Mystery Mod is, and I will miss its adopted name dearly.....
Its shape has been optimised (internally) for changing the way the plenum resonates in the 3800+ RPM range. The increased volume of the center plenum does help the torque band below 3800RPM but when designed wrong, looses upper end horsepower over stock. It took awhile to figure things out and many piles of scrap metal.
Additionally, the exterior has to be designed to accomodate the hood clearance and we have installed a few unwanted "power bulges" when shutting the hood or brake torqueing the motor.
Yes it will be in color if demand dictates....It will be Cast in a rough aluminum with a polished machined upper surface which is deep engraved with "RES" in italicized bold NASA lettering.
Peach Tea
Retired MOD
1 Post
Originally posted by WiGnTriP
will this new mod work on first gens???
Originally posted by noleaf74
where can i get one of these my resonators, everyone is mentioning tim, how can i get in touch w/ him?
Originally posted by Inspire
and just approximately how many hp will this mod give us?
O.G.
Originally posted by Bitium
About 15hp for the TL-P(won't work on 99's) about 20hp for the Type S.
Is Doug working on something to make the RES fit on our 99 TL?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Ed
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Retired MOD
1 Post
Originally posted by BlackShadow
Bitium,
Bitium,
Originally posted by Shoofin'TL
WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT? You just put a Major damper in my day!!!!!
I hope this isn't true!!
Ed
Ed
Okay, I haven't been keeping track of this mystery mod. And I think it's about time to find out more about it now that we know what it is.
(I'd rather follow someone's suggestion and not do "search" on the topic.)![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Bitium, are you the liason?? In any case, you seem to know most of the answers so we go:
1. If not 1999 models, how about 2000? (I don't think 2000 models are called TL-P).
2. Any factory warranty issues?
3. Any known side-effects/ downsides/ by-products to having RES?
4. Any warranty on RES? In other words, how long is the RES' workmanship guranteed for?
5. Will RES work in conjunction with the Comptech SC?
6. Any increase in noise level??
7. Will it be CARB certified? In other words, will it pass smog check in CA? (CA is one of the toughest places.)
8. How much will it be sold for? (Ball park figure?)
That's about it for now until it actually comes out. Thanks tons for the info.
Retired MOD
1 Post
Dude too many questions
all models are called TL-P except the type S. Yes it will work with 2000 and 2001. The 99's is the only ones that have a different upper manifold.
None
None known yet. Very unlikely to have one anyways since it only interacts with the stock manifold and not any other component, plus no moving parts.
I believe 2 years 25k miles, but I might be wrong. I'll check on this.
It should, but can't be tested until comptech finished development of the SC
NO
I should, it will be tested in the next month, before release to the market.
$300
None
NO
$300
Retired MOD
1 Post
Stay the same. In other words you won't notice a change.
Originally posted by VTEC Animal
One more question I don't think has been asked yet....
What effect does the RES have on gas milage? Does it go down or up, or stay the same?
Now I got one more question. How difficult might be installation?Is it something that can be done "at home" or it requires some professional installation? How much the installation might cost at acura dealership then? Thanks
Retired MOD
1 Post
I would take about 5min. Is very easy and yes it can be done at home or in the supermarket parking lot when you go shooping. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Why it takes so long to produce?!!!
Why the long wait to get it mass produced? It should have been here last week, I don't like to wait too much for it.... I am running out of patience....
saberlove
03-11-2021 09:29 AM
justin7779
12-25-2015 10:33 PM
mugen_kid
11-13-2015 10:38 PM
