Cabin Air Filter?
Old Apr 23, 2011 | 01:57 AM
The Noodle's Avatar
Cabin Air Filter?
The 02 has a cabin air filter? Anyone know where its at?
Old Apr 23, 2011 | 02:26 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
https://acurazine.com/forums/2g-tl-1999-2003-98/updated-diy-ac-cabin-filter-change-567712/
Old Apr 23, 2011 | 02:35 AM
The Noodle's Avatar
Originally Posted by princelybug
sweet! thanks man! Great DIY too
Old Apr 23, 2011 | 09:32 AM
01tl4tl's Avatar
didnt we already give you the master diy list link?
on cabin filter- comes 2 filters in a box for under 20 bucks- they sit side by side in a plastic holder when installed
ones with antibacterial or odor control have advantages over plain paper
on directions: no need for dremel to cut the small tabs holding cover over the filters
cut one sides with kitchen scissors or garage tool, bend panel back and forth and the other side tabs break off
To reinstall panel it goes sideways from original- has slip in tab and 1 screw to hold in place when done
dont worry that it doesnt cover the filters--its made that way
hopefully its been changed before so no cutting needed.
Do use the shop vac to remove leaves and unknowns from the vent lines
Old Apr 24, 2011 | 12:25 AM
The Noodle's Avatar
Thanks again man!!!! And look what I've found!!!! http://www.youtube.com/watch?v=Wv6b79Eeqvo
Old Apr 24, 2011 | 03:30 AM
01tl4tl's Avatar
amazing what info is on this interweb superhiway thing!!
Old Apr 24, 2011 | 04:23 AM
Skirmich's Avatar
Hey 01tl4tl
Have you tried the Air Filters with Charcoal (Anti-Bact + Odor)?? BOSCH Sells them for the 2G at 49.99 bucks But I dunno if the Extra 35 Bucks are worth it.
Old Apr 24, 2011 | 07:07 AM
fsttyms1's Avatar
Originally Posted by Skirmich
Hey 01tl4tl
For that price id just change the stock ones more often.
Old Apr 24, 2011 | 08:40 AM
totaledTL's Avatar
Good find Noodle. Can we get the video added to the cabin filter diy please?
Old Apr 24, 2011 | 10:31 AM
01tl4tl's Avatar
last time, I purchased Bosch antibacterial- 17$! local parts store
you can add charcoal to it if you want, a bottle from drug store is a few dollars, just rub some into the paper pleats
Also good for hangover~,,,or travellers revenge...(stomach expelling contents at High speed)
hospitals make you drink a cup of it w/water,,, before pumping stomach on OD cases,,,
No, its not grilling charcoal!!! `activated charcoal`
its an exellent `absorber` of toxins in many forms
you could probably use baking soda and get similar effect
Old Apr 24, 2011 | 10:39 AM
01tl4tl's Avatar
my suggestion based on what I use- anti-bacterial/anti-microbial spray added (bosch, maybe others) thats going to kill or stop pollens and really bad stuff from getting thru.
beyond that, is just air feshening stuff-- you have other choices on how to deal with
for way fewer dollars = box of baking soda, drops of essential oils on cotten ball in ziplock under seat,
Ozium spray if you want to kill anything from barf to cigarette smells --instantly
basic paper filters work well enough- if you dont live in areaas with constuction or you have allergies. In those examples- the better the filter the better you will feel after driving
I even use a small negative ion generator plugged into the `not a lighter`
Old Apr 24, 2011 | 01:21 PM
timmy8151's Avatar
Purolator has a $5 Rebate going on right now on their Cabin Air Filters. I've used them in the past without issue
http://www.purolatorautofilters.net/...cialoffer.aspx
They also have rebates on their Oil Filters and Air Filters as well
Old Apr 24, 2011 | 02:37 PM
fsttyms1's Avatar
I should change mine, i havent done it since the swap
Old Apr 24, 2011 | 05:51 PM
01tl4tl's Avatar
time for that, and clean the engine air K&N ,,,and oil change,,,,
Old Apr 24, 2011 | 07:19 PM
VQPower37's Avatar
how important is it really to replace the cabin filter, i mean when i walk around outside i breathe air and i dont see any problem with that y change the filter? why even filter to begin with?
Old Apr 24, 2011 | 07:31 PM
hANDYcaptd's Avatar
It's the Halladay season!
Air outside is circulating constantly. Once dust/dirt/pollen get stuck in the filter, it stay there. Doesn't take long for mold/mildew to form and come out of your vents.
Old Apr 24, 2011 | 07:53 PM
totaledTL's Avatar
If it gets clogged it can restrict the passage of air- hard on the motor, less volume of air gets circulated, lower system efficiency.
Old Apr 25, 2011 | 10:46 AM
01tl4tl's Avatar
sounds like someone who has not changed the filter yet!
afterwards.. you decide to wear a mask while outdoors, and replace cabin filter way more often!!
that black crud on the paper--otherwise would be on your lungs!
Old Apr 25, 2011 | 04:41 PM
swllen_cu's Avatar
great find on that video!!!! Will do this next week sometime!
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
hashbrown
Sep 29, 2015 12:13 PM
