A/C is just not cold enough
Has anyone else noticed that the A/C in the TL is not so cold? I have an '03 TL-S with 2,500 miles on it and it's been pretty warm here in NY lately. Yesterday I was driving and the temp was set to 61 degrees and it was still struggling to keep the car cool. My friend has an '01 Maxima and his A/C was colder then mine set at 70 degrees. Is there any type of recall on this? Another friend with an MDX said that he took his in for an A/C repair because he had a similar complaint and they replaced some hose. Thanks in advance for the input.
Donny
Donny
Don't know about any recalls but my AC works great here in hot & sunny South Florida, you might want to have it checked.
I have noticed that if I mess with the recirculate and auto buttons I get varying outcomes so you might want to try different combos with those buttons.
Get it checked ou
There isn't any specific AC problems in acura TL's per se that I am aware of. However, it is entirely possible that something is not quite hooked up correctly. I personally know someone whose AC was over charged at the factory, and as a result the AC could barely blow any cool air at all. Perhaps a valve is loose? Could be a leak. A leak would explain why your cabin isn't getting cool. Easy enough to get it checked out.
When my car has been sitting on the hot sun for a while, it takes a while for the A/C to kick in.... but i think that's normal. Just turn on the engine and roll down the windows and turn the A/C off. Wait outside for about 5 minutes and start driving... the more you drive the cooler it will start to get.... i may be VERY wrong... if so my apologies in advance.
Originally posted by BadAzzS
My windows are tinted and my '03 TL-S still has me sweating at 60! I have the same problem as you do, maybe it's just the north east
Originally posted by juniorbean
Nope, can't be the Northeast b/c mine works normal. Even when it's in the sun all day at work I get in the car, turn on the AC to about 68 degrees at about 1/4 powers and it cools me down almost immediately. It does continue to get cooler as the car warms up, but it's pretty cool to begin with.....
My AC works very well. I wake up in the morning, get out of the shower and while I am eating breakfast I hit my remote start and S-Windows on my alarm and by the time I get to my car its freezing!!!I love it!!! The best investment I have made on a car!
I bought my TL in california and it was cold as alaska. I drove the car to arizona and it was not cold. I went to auto zone and bought an A/C recharge kit and did the rechagre myself. It was easy and only took about 2 or 3 minutes.
AFTER THAT IT WAS DAMN COLD!!!! you have to recharge the A/C with the car running I found out.
I think you just need to recharge the A/C and it probably couldn't hurt to put some leak sealer in there to make sure it doesn't leak again.
Instead of recharging it yourself take it to the dealer under warranty. My car is just fine in NYC, and I too have to turn it down because it blows too cold. I do have 35% tints all around though. I usually have it set to around 70-71 degrees, on a few times down to 66. Never lower.
You may be low, but you can also be too high. Happened to my uncle with his new Max. They actually had to empty it a bit and it worked just fine again. Take it to the dealer.
Hey Donny it must be your car. I have 3250 on my Type-S and everything is fine. Even when the car sits in the sun for a while it takes seconds for it to blow out cold air.
Btw, I still want to meet up to check out your strobes, I was really busy for the past 2 months. I still have your e-mail somewhere. I hope we can work something out.
Go to the dealer.
Go to the dealer.
My A/C works great on my 2000TL as it has done for the over the last 2years. I use mine alot because of allergies I almost never have the windows down when driving. I do open the sunroof to vent. It must be your car take it back to the dealer. The A/C in the TL is better than most other cars. You have a 2003 are you sure you are working the A/C in the proper manner?
#1 MAKE SURE ALL VENTS ARE OPEN IN THE CAR
#2 SET THE TEMP DOWN TO LOWEST 60
#3 PUSH YELLOW REC BUTTON
#4 SET FAN SPEED TO HIGHEST SETTING 5
#5 AFTER CAR COOLS DOWN PUSH YELLOW REC BUTTON BACK TO FRESH AIR MODE.
If your butt does not almost freeze in your car there is something wrong with your A/C.
Originally posted by AcuraTLFan
Step #5, you don't press the yellow rec button to get fresh air.
If you want it to be cold, you keep it on recirculate. The system recirculates the cool air instead of the warmer air from outside
I am correct after the car cools down push REC yellow light on the light will go off & its back to the fresh air mode. You don't want to keep it in the REC mode for long periods of time this is how that bacteria ordor get in the system.
Remember that the speed of your car (at least when getting in a hot car) can affect how quickly it cools down.
When you're standing still, or driving at very slow speeds, the A/C relies entirely on the fans in front to pull air through the condenser (remove the heat from the system). If you're driving at faster speeds, the volume of air going through the condenser is greater, and the system sheds heat better.
Once the car cools down a little, the system has plenty of capacity to keep it cool - regardless of speed.
I guess this is just one more reason to drive fast!
First you should make sure all your vents are open.
Two i keep mine blowing out of the main vents on the dash then switch to dash n foot after it gets cold to maintain the temp.
Three make sure it is on re-circulate
Four if your car has been baking in the sun open all your windows
and drive for a minute to let all the hott traped air to escape first.
Five if all the above fail take it to the dealer to see if there is a problem with the ac system.
If I read your logic correctly I think you are mistaken. If the car has been sitting in the sun with the windows up, it works best to roll your windows down (as was stated) and/or run the A/C without the recirc button lit. This way you draw in outside air. This is actually better because the outside air is actually cooler than the air inside your car for a period of time until the A/C catches up.
Example: My dark blue Suburban gets up to about 140 degrees inside on a 90 degree day after sitting outside for awhile. Most A/C systems are only good for about a 40 degree differential in temperature (subtract temp vent exit from temp blower input). Any system works much better & quicker trying to cool down 90 degree air (90-40=50) than 140 degree air (140-40=100). Once you get the inside/outside temps equal you can use the air on recirculate or whatever.
Recirculate is actually more efficient because you are cooling already cooled air and therefore the A/C does not need to run as much. This means less strain on the engine and other A/C components. It should also mean slightly better mileage as a result.
Anyone know if our car has a variable displacement a/c compressor? It seems like it to me. The car seems to lag more at high cooling demand, vs. low demand.
If so, then a higher thermostat setting will give you noticeably better mileage.
eCo
eCo
16GS FSprt,03Max,12 335is
Our cars just dont get as cold as most American cars for some reason. Neither My Maxima or TLS gets as cold as my sisters Seville and it has been 95 degrees here in Dallas, their is a difference that you can notice between them.
Originally posted by NsX Pilot
What year seville was it ?......could it have something to do with the v8 ?......How big is the cabin as compared to the other cars ?
Re: A/C is just not cold enough
Donny
Donny
Anyway, to make a long story short, my aspirator tube was never connected to the vent system, at the factory. So, the temperature sensor wasn't reading the temperature of air being "drawn" past it, but simply whatever air was right around it.
This could be your problem.
recirculate button
I have a black/black 2002 TLS and the AC cools the car down ina few minutes even on a hot sunny day. I've seen people on this forum state that you will get odor's from the AC if you keep the button on recirculate all the time and I never do. I live in a very humid area and if you keep the system in the normal mode all the time the AC is always pulling hot humid air from outside to cool the interior. This is OK for fresh air but in a humid area like central PA the extra humidity has to be removed by the AC coil and the water drips outside the car. This extra moisture is MORE likely to cause a problem than the lack of fresh air. I still use the normal (fresh air) mode if the air outside is "fresh" but not on a hot sticky smoggy day. That just makes the AC work harder to cool the car. The air in the car smells fresh and still has the "new car smell" after 14 months. Try it and see. My AC stays on recirculate most of the summer with no problems.
Ok, below is the Number One reason why an otherwise perfectly operating car AC may not seem to be cooling the car enough - everyone ready? :-)
CLOSE YOUR SUNROOF COVER.
Really. It makes a HUGE difference, especially on a 95+ degree muggy day.
I had the AC on my Saab checked over and over again until I finally started doing this - nice ice cold AC ever since.
Keep in mind that most AC systems are only really designed to lower the temperature by about 25-30 degrees compared to what's outside, otherwise the windows would condense and fog like crazy.
If you have the glass cover open and the sun beating down inside your car, your AC really needs to struggle to keep up.
If it's nearing 100 degrees outside, that means even on the best setting your car will only cool down to around 70-75 degrees, which may seem warm to some people.
If you doubt this, note how fast and how hot your car warms up inside when you run into a store with the cover open and the sun beating down inside your car - then time it and do the same when its closed.
Biggie_B
02-26-2017 11:14 AM
rcs86
08-02-2016 06:52 PM
