Break Problem
Old Jun 10, 2003 | 01:55 AM
KidD WiTh 2k TL's Avatar
Break Problem
i was changin my suspension to full tein and i had problem with getting one of the rear shocks out so i took off unscrew the break line and now my breakin is not sensitive at all . . . what can i do to get it back to normal? . . . any help please?
i need to basically floor the brake to come to a complete stop . . . it dangerous and dont want to do anymore driving until i get the problem solved.
Old Jun 10, 2003 | 02:16 AM
NSXDreamer's Avatar
:wow: when you unscrew the brake line, what do you mean by unscrew?? did you unscrew it from the caliper? would you probably got air into your brake system?? Check your master cylinder and see if there's enough brake fluid in it, I suspect you lost quite a bit brake fluid after you "unscrew the brake line" and introduce some air in the system in the process.
Yes, it's very dangerous, and based on FWD car only use the rear caliper for less than 20% of the braking. Even you totally screwed up your rear brakes, you should still be able to stop just fine. There's really something wrong in your car's brake system.
Old Jun 10, 2003 | 08:41 PM
limitedTLS's Avatar
just bleed ur brake system...does ur pedal feel spongy or anything like that...just bleed it and see want happens
Old Jun 10, 2003 | 09:04 PM
fsttyms1's Avatar
if ou took the brake line off you will need to bleed the brake system starting wit the farthest brake from the master cylinder working your wat to the closest. or just bring it to a brake shop and let them do it.
Old Jun 11, 2003 | 03:38 AM
NSXDreamer: yea i did unscrew it from the caliper
how do i bleed my brake system? . . .
im clueless but i felt that i did something very stupid but i was so fustrated with the struct not coming out. do u think the dealer could do anything or just dont deal with them and take it to a brake shop?
Old Jun 11, 2003 | 11:12 AM
Strannik's Avatar
I am sorry to say, but you did do a very stupid thing. If you do not know enough about your car you should not unscrew anything - you are talking about your life here!
You do not have to take it to the dealer - I would SLOWLY drrive to the nearest shop that does brake work and get it done there.
GL
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
