Brakes
Old 03-29-2010 | 05:41 PM
mmendelzon's Avatar
Brakes
my front rotors are warped and need to get new rotors and pads
is it possible to change the rotors on my own or a shop the only way to go?
i know the brake pads can be done easily on my own
Old 03-29-2010 | 05:49 PM
Rajca's Avatar
wham bam thank you ma'am
if u have some basic tools, its easy and quick. the screw that hold the rotors in place might be stuck and a bitch to get out, either get an impact screwdriver or a drill and drill out the screws. u dont really need them
Old 03-29-2010 | 05:53 PM
assclown's Avatar
2000 acura tl FPR
^what he said,
it's very easy, just take your time and have some beer.
Old 03-29-2010 | 05:56 PM
mmendelzon's Avatar
brake pads ar e easy though right?
Old 03-29-2010 | 06:04 PM
Rajca's Avatar
yup. simple. few bolts, just break them in properly. torque down the wheels in teh correct pattern and correct torque
Old 03-29-2010 | 09:43 PM
'02_TL-S's Avatar
Traded in my
This guy knows what he's talking about.
Brake jobs on disc brake equipped vehicles are a piece of cake. It's drums I wouldn't recommend for someone with little experience to do.
Impact screwdriver FTMFW against those damn rotor screws!
Old 03-29-2010 | 10:13 PM
Rejckt's Avatar
I had to drill that shit out, took forever to drill out too...
Old 03-29-2010 | 10:23 PM
MOBB's Avatar
Why you can just pop in a small L key and itll pop right out when stuck. Thats what that tiny hole was made for!
Old 03-29-2010 | 11:25 PM
mmendelzon's Avatar
thanks guys
is there a post specific to changing the brakes? step by step?
Old 03-30-2010 | 12:31 AM
01tl4tl's Avatar
have you looked in the DIY section- everything is there
including painting the calipers and rotors, flushing the brake fluid and more
Old 03-30-2010 | 09:45 AM
assclown's Avatar
2000 acura tl FPR
impact screwdriver took out 3, i had to drill out 1
Old 03-30-2010 | 10:09 AM
gold2003tl (90)'s Avatar
2003 TL-p
i had to drill out all 8 of them set screws. i broke 3 bits on my impact screw driver and they weren't moving . damn road salt.
Old 03-30-2010 | 11:28 AM
01tl4tl's Avatar
here is a trick- on any really corroded bolt-screw-whatever
First shoot wd or similar at it and let sit
Now take your impact screwdriver (or wrench on bolts) and try to TIGHTEN- righty tighty... give the tool a few solid whacks with a hammer
That often disrupts the bond of crud in the threads
Now go Left, setting to loosen and a few good strong whacks will get them loose.
Make sure to coat a few threads on the screws with spark plug anti-sieze or caliper grease so they dont stick again
the rear rotor screws help when you need to adjust the park brakes- which are a mini set of brake pads with the hub center as their drum- see how wide the rear rotor hub is- thats your park brake shoes! Having the screws hold rotor in place while you adjust (when doing during brake job) is a big help
to adjust park brakes- you have the pads off so you can hear drag-- adjust brake shoes,
OR tighten star wheel adjuster till tire wont move by hand- now back off 6 clicks- should be a slight sound of drag as wheel rotates
That will give a secure park brake setup
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
rockyboy
10-02-2015 10:45 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Brakes
