Blower motor doesn't work, replaced harness, transistor
Old Mar 30, 2010 | 12:52 PM
dannheisser's Avatar
9th Gear
Blower motor doesn't work, replaced harness, replaced transistor, tested existing blower by battery, tested another blower, any ideas???
Could there be a problem with the a/c-fan $ contol switch?
Old Mar 30, 2010 | 01:26 PM
fsttyms1's Avatar
you tested a different blower and it still doesnt work? If so then i would check the control switch.
Old Mar 30, 2010 | 02:59 PM
9th Gear
HOw do I go about testing the switch?
Old Mar 30, 2010 | 07:45 PM
01tl4tl's Avatar
power at fuse box? then test along the system till you reach the dead zone
is it a NAV equipped car with electronic control or the regular dash with basic 3 position fan speed switch?
remove switch and see if there is power to it, and power coming out
Was any wiring damaged when you started this project? reason for all the parts?
Old Mar 30, 2010 | 07:46 PM
01tl4tl's Avatar
existing blower test at batt- you hot wired to fan and it worked?
suspect switch
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
ibGTV
Sep 28, 2015 03:40 AM
Desert Ridge
Sep 5, 2015 09:47 AM
