Need Help with 03 TL S Front Driver Window
Old Mar 27, 2010 | 06:13 PM
TypeTLs's Avatar
3rd Gear
Hi I just bought a 2003 Acura TL Type S. My driver side front window has not worked since I bought it.
I first tried putting power to the prongs that make the motor go up and down, and it worked, the window went up and down. So I then ordered a master window switch and it still didn't work. I then ordered the window module and the window still does not work when pressing on that window button.
I looked for snagged or loose wires and could find nothing wrong. I pulled the window fuse under the hood, and that stops all the windows from working and when plugged back in, they all work but the front driver.
What could cause this problem, does the computer need to be reset or something of that nature?
Any help would be great thanks.
Old Mar 28, 2010 | 03:46 AM
BaByBlAcKtYpE-s's Avatar
Is the window lock thing locked? I don't remember if it has an affect or not just something to look at.
Old Mar 28, 2010 | 10:43 AM
TypeTLs's Avatar
3rd Gear
To BaByBlAcKtYpE-s
Are you talking about the window lock button, if so that would effect all the windows not one.
Old Mar 28, 2010 | 06:26 PM
kapikia's Avatar
3rd Gear
find the wiring schematic, and check to see if the switch is getting input power, and if it is sending output power on the appropriate wire when the switch is pushed up/down
Old Mar 30, 2010 | 09:11 PM
TypeTLs's Avatar
3rd Gear
To kapikia
Where do I find a wiring schematic?
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
ahsm
Sep 9, 2015 08:35 AM
gqdabien
Sep 8, 2015 11:41 PM
08 NBP TL
Sep 8, 2015 08:49 PM
