Brake Rotors
Brake Rotors
Hey guys. Long time. I found a company on here a few months ago that sold slotted rotors that most people dealt with on this forum, but forgot the contact info and name. Can anyone chime in please. Thanks in advance. I have an 02 TL.
Thx guys. I just bought the slotted/drilled rotors from Brake Motive. Anything will do. My steering wheel shakes so bad it scares me when I brake.
Way over due.
Way over due.
Brakemotive first set warped within 2 months they sent me a new set front set gone after a year they have hot spots, dont cheap out or u will be buying rotors again very soon
<------- learned from experience
purpose of the side slots is to allow pad outgassing to have an escape path-
otherwise gas pressures can exceed the calipers ability to keep pads against rotors = pads can be pushed OFF the rotor while you are holding full brake,,at speed
this usually only happens under extreme high heat from repeated applications
hot spots on rotors can be from hard use or even repeated 45 to stop traffic-
then no cooling airflow by moving again = pad sits in contact with rotor with brakes applied- car stopped = heat sits on one spot on rotors..
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
