Beefing up an auto Tranny? how/where/how much?
#81
318whp/289wtq @ 6psi
Well I know how much the dealer sells them for so feel free to call any of the dealers in the Maryland area. By the way, I don't want one of your cause I have been lucky enough not to have any transmission issues. I like the way i think, i never said it was expensive other than it was more than a rebuilt one from Dr. Evil. Get your facts straight. Maybe you do need to find some more customers!
#82
About a year and a half ago I got a transmission replaced because of an car accident and was told by the service advisor that the "reman" transmission from Acura was $5600 and the one from Howard Engineering was $5900 or vice versa, can't remember but then again maybe they told me the wrong information. Oh well.
#83
On the way!
Originally Posted by blk2001tlon19s
Well I know how much the dealer sells them for...
"Get you facts straight..."
#84
Originally Posted by fla-tls
A new tranny from the dealer is not $5600. It's more like $4500 - ask optiq. Or better yet, read the whole thread - it's in here. If dealers in your area are charging $5600 w/o install you might want to have your car towed to another state. It would be cheaper.
You haven't a clue about my shop, so don't judge so quickly. BTW - I love your use of the English language.
Refer to item 1 - they appear to be the same price. The difference - warranty. Anyone who thinks a $4500 tranny with a 6 month warranty is a good deal needs to get their head examined. I don't care how "built up" the tranny is.
Refer to item 2 - I do just fine, thank you!
100% right!
blk2001tlon19s you need to call around a little bit. I can get a new tranny from my dealer for the price of the dr evil tranny, which i have doubts that it will hold up, and like fla-tls said a 4500$ tranny with only a 6 month warranty IS NOT worth it no is it a good deal!
#85
ChairmanMaoSaysRTFM
Originally Posted by fsttyms1
To put it simply its HEAT. the honda engineers found that durring shifts the 3rd gear clutch packs were reaching over 350deg CELCIUS Thats over 662 Degres F. Nothing will last.
Kevlar will not begin to decompose until 400degC (according to DuPont) and carbon is better than that, so a carbon/kevlar clutch should not self-destruct at these temperatures in the tranny (~350C), unless it really is going over 400degC inside (which is higher than originally thought). perhaps we need to revive the old asbestos plants.....
SSTS
#86
Originally Posted by SatinSilverTypS
not trying to be a dick, but we allready knew that. unfortunately it really doesn't answer my question though.
SSTS
SSTS
Later today ill take pics of the 3rd gear clutch packs, plates and drum so you get a idea of what things look like
#87
ChairmanMaoSaysRTFM
Well according to honda and the tech that i spoke to heat is the killer. yea kevlar may hold up better but it wont last. Its in a confined area and it retains heat. the more heat that is created in that area (in side the 3rd gear cluch drum) the more slipping occurs and the more slipping that happens the more heat and wear occur, when this slipping occurs it creats debris, and it inturns plugs the selanoids that help it to shift (which are Very pricy on the TL) then more slip and wear happen. The tech i talked to (35 years of building trannies) said hes used carbon/kevlar clutchpacks and they still wouldnt last long in this application due to its design. there just simply isnt enough cooling
it can't hurt to dream...
SSTS
#88
On the way!
I can't wait to get my first one in. I want to see if there's any other sort of fix that could be applied to make sure the clutch packs get enough fluid.
Who knows... it may be my own! j/k - I only have 60k miles.
#89
that would be really cool if you could do that. maybe i'm just having trouble visualizing it. what does nissan use for a lubrication design? i've seen 340whp maximas running around with their stock trannies. maybe we can take a lesson from them unfortunately the designs are probably apples & oranges.
SSTS
SSTS
Its not so much what they use different but how they use it. Its just a poor internal design for fluid delivery.
#90
#91
Cant take them tonight. (forgot parents have camera) ill get to them before the weekend!
Stay tuned for your local news next
#92
akaYUNG LEE but im Chico
Originally Posted by mrsteve
Why on earth would you want to do that to this car? Trust me I've been there.
If you don't have the complete info how do you know you have the money? It's going to cost damn near $10,000 or more to do a 3.5L stroker plus the supercharger if you want it done correctly. Why put that kind of money into a car that isn't worth more than $18k to begin with?
Take my word on this, i've been there. I'm on my second CL-S and my second supercharger (one for each car). It makes the car a blast to drive but honestly it isn't worth it and I won't do it again.
I buy cars from auctions in case you guys are wondering and i get them very cheap, but these 2 acuras im going to keep. Steve, how much whp do you think the cl-s 6 speed can hold if you drive it everyday and occassionally you step on it full throttle?
oh yeah thanks very much for the helpful info everyone has posted..thanks for the website links to the tranny shops.
#94
Don't jump on the throttle before the engine has reached operating temperature.
Allow some time between jumping on the throttle to allow the "hot spot" to cool down a bit.
#95
Originally Posted by Southern
From what I read there are several things that can extend the life of the trans:
#96
so what your saying is floor it once and drive normal for awhile to let it cool? great in theory but not going to happen. Simple city driving will make that impossible. you dont have to be flooring it to generate heat. any time it shifts it creats heat, and if its constantly shifting well you get the idea. There is nothing that we can do as a driver/owner to prolong them or keep them from failing. (this side of parking it in the garage and not driving it)
#97
The heaver the throttle = harder shifts = more heat. Apperently the 350 deg. C "hot spots" comes with harder shifts.
#99
Originally Posted by optomos
Anyone have a pic of the tranny that shows the 3rd gear clutch pack.
#100
i have the 3rd gear parts, just havent been able to get my camera back from my parents yet
I might have an idea on how to prolong tranny life by maybe >2x.
#101
When you get your camera back post some pics please.
Ill try to get them soon
#102
How might that be? From hondas tech and tranny guys it needs better cooling (and with out a redesign there doesnt seem to be a way) (there isnt a external way)
#103
Originally Posted by MikePA
What about drilling a hole above the 3rd gear clutch pack and somehow spraying cooled tranny fluid on it?
#104
Sorry dont mean to burst any ones bubble but this is the way it is
So the clutch pack doesnt even come into contact with oil? Hmm. Anyway we can get an exploded view of the tranny.
This is the 3rd gear clutch pack there is alot to it. the upper pic is what all goes into the drum
#105
Ok. I was thinking of cry-treating the part, but in this case Id say cryo-treat the whole tranny. It would cost about $250 to 300$. It wouldnt give you a "bulletproof" lifetime tranny, but it would extend the life of the tranny dramatically. Id still like to find out what metal the gears are cast out of. Im thinking iron, which would explain why they deteriorate so fast.
#108
#109
On the way!
$300 wouldn't cover pulling the tranny, taking it apart, treating it then reversing the process, would it?
We'd charge $399. That's our standard inspection price which includes those steps that you mentioned. While you're at it - you might as well get a soft parts overhaul which includes new clutch material and seals/gaskets.
#110
- but close
#111
On the way!
So, it'd be $399 + $250 or $300 (treating) + cost of soft parts. Might be a good alternative if the treatment would help the tranny last longer.
#112
ChairmanMaoSaysRTFM
cryo-treating is some great stuff and it would definitely increase the power handling, but i have a feeling it won't solve the issue at hand.
but i have to say, have we overlooked the obvious here? what are the 3rd gen 5AT internals like? can we mix and match anything there? i'm sure this has been looked at but i just haven't heard anything. anybody know? surely there must be some lessons we can learn, or some interchangeable parts.
also, what are 500hp clutches in manual trannies made of? has anyone looked at similiar materials? maybe this would help to stave off the quick degradation. now obviously i don't know alot about how transmissions are built but if i'm wrong i'm happy to hear it and learn.
SSTS
SSTS
#113
cryo treatind wouldnt do Jack for our cars. The metal parts arent breaking! there are friction material pads like a clutch on a manual but a much much smaller version (all the #3's in the pic above) they are whats wearing out due to heat
SSTS
This is a completly different thing! Manual clutches are Dry and alot larger, They arent designed to do the slipping between shifts like a auto
Have you priced out the parts for the TL Yet?? they are expensive (especially the selonoids which is recomended you change in the TL)
SSTS
Soft parts overhauls start at about $1500+ for most cars. The rebuilding process contains more labor than a simple tear down/inspection.
#114
On the way!
With regard to solenoid replacement... Where did you hear that they should be replaced - even if they check out as ok? I'm not against the idea - but unless there is a redesign issued or some problem shows up on an individual solenoid - why replace it?
(Don't get me started on BMW / ZF tranny solenoids and their negative ground actuation... That is the most back-ass design I've ever heard of. The computer can hardly ever tell if there's a problem! Apparently the computer cannot register ground faults!)
#115
I'm not going to price out parts for a TL until I have one in the shop. It's not worth the time - as things will change from day to day in the aftermarket.
#117
Originally Posted by ratpack
So how much does a rebuilt tranny with a 12month/12,000 mile warranty go for?
#118
this is kinda off topic, but is the comptech transmission cooler only for cars with a S/C or will a modded(exhaust,intake,cat,headers) also see a benefit.....
The reason i ask is my speed shop said i should expect problems with my transmission since ive been incresing the power of the car, He said "stock tranny not built for this" So is the cooler a good buy for me or should i start saving for a dr evil....
thanks in advance
thanks in advance
#119
thanks in advance
thanks in advance
