Baking Headlights Question..
Old Sep 17, 2009 | 02:45 AM
Davinci27's Avatar
Does baking your headlights make the chrome inside dull, due to the heat?
Old Sep 17, 2009 | 03:08 AM
iforyou's Avatar
You'll Never Walk Alone
didn't happen to mine.
Old Sep 17, 2009 | 02:12 PM
WDPTLS's Avatar
not at all, if you follow the DIY on it you should be golden.
Old Sep 17, 2009 | 02:13 PM
jjashaa's Avatar
Avant Garde Wheels
Old Sep 17, 2009 | 02:20 PM
jrb9790's Avatar
jjashaa = major major nerd lolz
Old Sep 17, 2009 | 02:41 PM
VoLLy's Avatar
Meridian
using a heatgun is a much better alternative so you dont have to rush (thus bending the headlight when prying it apart) to open the headlight when the butyl starts hardening while its cooling off.
Old Sep 17, 2009 | 02:54 PM
It's Clutch's Avatar
Hello Officer
a hairdryer works as well.
Old Sep 17, 2009 | 03:18 PM
andrew070489's Avatar
u would recommend the oven, if your worried of messing up just take them out a couple minutes earlier and check to see how pliable it is. after all the little tabs are popped gently pry to 2 halfs apart.. it wont mess up the headlight inside. i would recomment oven method
Old Sep 17, 2009 | 04:42 PM
fobstylez's Avatar
hey ive taken apart about 3 sets of TL headlights and on my retro I took it apart like 3 times. First time ever I used a heat gun, very very bad idea. It does work, but it takes way too long plus sealing it back its better in the oven because its consistant with the heat, whereas if you use a heatgun by the time you get around the other sides are cold. Only time I had my headlight leak was from the heatgun, oven, none. Just speaking from experience.
Old Sep 17, 2009 | 06:03 PM
SLushhYYY's Avatar
Keep It Simple in
lol hairdryer ftw
Old Sep 17, 2009 | 07:05 PM
6MTUA5's Avatar
No He Can't
That's how I did mine. Heat gun will work too just be careful.
Old Sep 17, 2009 | 08:07 PM
Rajca's Avatar
wham bam thank you ma'am
oven for me and others that i did. no problems, just dont touch the chrome, and if u do dont try to clean it off while the chrome is still warm/hot. the chrome will start to come off. clean it off when its at room temp. with a microfiber towel and some glass cleaner/ invisible glass
Old Sep 17, 2009 | 08:29 PM
Davinci27's Avatar
Well, I can see why the oven is better, more consistent. I guess No Guts, No Glory! Wish me luck. Dealer wanted to charge me 300 bucks for removing the bumper, did it myself, so why not go all the way.
Old Sep 17, 2009 | 08:32 PM
Rajca's Avatar
ur dealer is a rip off. ive been reading more and more about these dealer ships that charge outrageous prices. wtf
Old Sep 17, 2009 | 09:27 PM
Cochese's Avatar
Sabotage
300 bucks for bumper removal.......ouch!
Did mine in the oven and turned out fine.
Old Sep 17, 2009 | 10:28 PM
acuraspeed604's Avatar
just did mine one of them leak so im gonna redo it and yea the head gun works but does get a bit to hot melted some of my tabs im i screwed mine up i got some paint inside one of them so i had to wipe it down with paint thinner now there a haze left inside now
so im gonna give it a plastic polish see how that is and just to go over the silver strip on the outside whats the best way to get that off i sanded it with some sandpaper got most of it off but its still whiteish and if if i was to redo them whats the best wayy to open em up again seeing that i sealed them with silicone
Old Sep 22, 2009 | 11:39 AM
teggy turned tl's Avatar
ok i think im missing something here why is everybody baking there headlights ??
Old Sep 22, 2009 | 12:45 PM
Lsamir53's Avatar
Always go big
To paint their housings black...to clear the amber turn signal..to do a projector retrofit..and i'm sure there's other reasons...
Old Sep 22, 2009 | 01:31 PM
DC3328's Avatar
Your Garage
they taste better baked
Old Sep 22, 2009 | 02:11 PM
Neejay's Avatar
I was going to do this, but my lens has some discoloration on them, so I know it'd show up a lot if I black the housing. Sucks.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
