AV6 swap done, now problem with SS and D5 light out
Old Nov 2, 2012 | 06:44 PM
mmakam2's Avatar
Just got the swap done, now my SS won't work and my D5 light won't stay on. D1-D4 lights work, transmission seems to shift fine. Anyone have a clue which sensors on the AV6 would cause the SS not to work?
Old Nov 2, 2012 | 07:02 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
What did you swap? If you swapped everything like I said there should be no problems
Old Nov 2, 2012 | 07:03 PM
mmakam2's Avatar
swapped, the range selector, all the oil cooler/heater lines, thats it. what else needed to be swapped?
Old Nov 2, 2012 | 07:04 PM
mmakam2's Avatar
the harness as well...
Old Nov 2, 2012 | 07:28 PM
Did you swap the 3 and 4 gear pressure switch harness
Old Nov 5, 2012 | 06:22 PM
mmakam2's Avatar
ok, so apparently the range selector switch wasn't completely connected.... doh!!!!!!!
thanks again stephen00tl
im replacing my pressure switches now, i keep hearing stories that they smooth out shifting a ton, and i get slightly rough shifting into 3, 4
Old Nov 5, 2012 | 10:35 PM
Mine has a positive shift into 4th but I already new that because of 666worker posted it when he did the swap. My guess is it has something to do with the shorter gearing in fourth
Old Nov 6, 2012 | 02:17 PM
mmakam2's Avatar
i kind of feel like it takes too long to shift into 5th gear or overdrive i guess. when i accelerate maybe 1/3 wot get to about 45-50, and completely get off the gas, it takes a while for it to shift up to 5th, does yours do this? also when braking and it downshifts, i can feel it, which is odd because i dont feel it in other cars.
overall the trans feels so much better than the old one, the ratios and the smoothness of shifts. feels quicker from a stop and shifts much quicker.
once i get the pressure switches in ill update status
Old Nov 6, 2012 | 03:37 PM
Mine does the same exact things you describe.
Old Nov 9, 2012 | 11:14 AM
mmakam2's Avatar
good, then its not a problem with my transmission, I put the 3/4 pressure switches in, definitely smoothed out shifting in the upper gears significantly, i am glad i did it, and if people are right about longevity, thats good too.
Old Nov 9, 2012 | 12:11 PM
I also did a 3x3 drain and fill with in the first 1000 miles of swapping it to get the old fluid out
Old Jun 10, 2014 | 05:34 PM
menk6154's Avatar
how do I find 666worker diagram for swapping out 2000 tranny with 2006 or 2007 model. I have a four door and the yards I call say that their is a difference between a coupe and sedan,,,please advise
Old Jun 10, 2014 | 09:35 PM
Memphlow's Avatar
https://acurazine.com/forums/2g-tl-1999-2003-98/faq-06-07-av6-transmission-swap-905115/
justin7779
Dec 25, 2015 10:33 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Skirmich
Sep 15, 2015 06:41 PM
02tljj
Sep 11, 2015 12:37 PM
HeloDown
Sep 8, 2015 06:51 PM
