Anyone Replace interior bulbs
Hi all, driving around last night, I happened to notice that some of my interior lights have burned out. There is a dim portion of my speedometer near the top and the lights for the "auto" and "off buttons" of the A/C controls appear to have burned out. Does anyone know how to replace these? Is it easy? Any DIY for these areas? Puhleez help!!!
You're going to have to take apart the dash and center console to get to those bulbs. Replacing the bulbs is the easy part - they just twist and pop out. Dismantling the dash will take a little while if you've never done it before. Do a search for DIY to take apart the dash/console; it's a good thing to know how to do for future projects/repairs. Someone probably has a schematic of the dash to ID the location and part# of the bulbs. Good luck!
http://files.subtledream.com/TL/reve...low_gauges.htm
Originally Posted by PenancE
hey, r those bulbs behind the dash/ac control, the same base as the door and dome lights? (exc middle dome.)
Originally Posted by fsttyms1
you will have to remove the black dash piece. use this diy to remove it
Nope
Nope
Wow, it sure does look like a bit of work. I guess I wouldn't mind opening up the dash to get to the center console lights but getting behind the speedometer gauges are kind of scary Any one our there have a schematic of the dash, pretty please?!?!
what do you need a schematic of the dash for?
BTW Is there any possible way that I could screw up the needles just removing the gauge cluster?
Just thought it would be good to have just in case I'm a handyman to an extent but I hate going based off a few pics if you know what I mean. Thanks, by the way, for the DIY!
Its not as hard as the pictures make it look. dont get scared by it. its not difficult, just take your time!
no. as long as you dont remove teh cover you will be fine. Just MAKE SURE NOT to turn the key to the on position with the gauges removed!
Cool deal bro! Thanks for all your help
ASSEMBLED TO PERFECTION
asahrts
09-04-2015 05:55 PM
