Anyone had this Problem???
Old Jan 25, 2005 | 06:01 PM
RiceRocket's Avatar
Angry Anyone had this Problem???
I have a problem, please help! I was out today and after getting back in the car starting it, the car was iddling really funny, the RPM gauge was jumping around like crazy. My engine even shut off me, and when I started it again, the car turns on but the same thing with the RPM gauge, jumping around from 1k-1.5k and it wanted to die on my again. I tried to give the engine a little rev to see if the fuel is line is clogged but it was alright.
The strange thing is that when I put in gear, it doesn't have this problem. This only happens when I have in park, and starting it. As for driving around, stopping and go traffice, it doesn't have this problem.
I also tried putting in gear and then put it back into park, there was no problem. If you guys have any suggestions, please let me know. I have a 00 TL-P. The only thing I have in it is a K&N. Thanks guys.
Old Jan 25, 2005 | 06:17 PM
moahdriven's Avatar
i
no idea. mine engine would shut off a while ago if i reved it high then braked fast, but that was in gear as well. My car was f'ed up then with electrical problems (fixed under body shop warranty) and tranny problem (recalled).
Old Jan 25, 2005 | 06:47 PM
moahdriven's Avatar
i
id suggest take it to dealer if u cant figure it out
Old Jan 25, 2005 | 07:00 PM
Lucky37's Avatar
so does the engine actually rev to those rpm's or does the gauge just play around like that? if its the gauge, then its one, if not both, of two things:
Either there is a bad ground somewhere - most likely, in fact extremely likely,
or, the main relay is gone, easy replacement, i think its like $50, but i would strongly suggest taking it in to a mechanic, they have tools that can pinpoint a bad ground. Hope this works out for you.
Old Jan 25, 2005 | 08:17 PM
RiceRocket's Avatar
When I tried to keep a contanst rev, 2k, the rpm rev right at 2k. Ahyhow, I started up it later tonight and no problem at all.
Thanks for the help.
Old Jan 25, 2005 | 08:44 PM
JimmyTLS's Avatar
It could be a bad IAC valve. Anyways, you should really take it to the dealer and have it looked at.
Old Jan 26, 2005 | 09:13 AM
Elementz's Avatar
My '00 TL-P did the exact same thing this past weekend. I started it and it was idling real crazy, like the timing was off or something. I restarted the car like 4 times and it continued, so I finally decided to take it around the block. By the time I hit the main road, it stopped and everything returned to normal. I haven't had the problem since.
Was your emitting some thick gray smoke from your exhaust? Mine was.
Anyway, I am going to take it to the dealership soon. Its time for my 60k service anyway.
Good luck.
Old Jan 26, 2005 | 09:16 AM
cljw's Avatar
Have the dealer change the IAC valve. My 03 was doing the same thing and once that was changed, no more problem.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
