alternator fitment question
Old Jan 15, 2008 | 05:22 PM
headbussaboi's Avatar
Just wondering if an alternator off a 2003 Accord V6 will fit my 2002 TLS?
Old Jan 15, 2008 | 11:22 PM
dsickles's Avatar
crossed the PN at work and no, it doesnt look like it.
Old Jan 16, 2008 | 07:37 AM
fsttyms1's Avatar
alot of hondas part #s are different from the acuras and are actually the same or will work. As for if it will work?? Also you would want to check to see what the amp of the accord alt is compared to the TL. Also look for the 98-02 accord, that was the same body as our tl
Old Jan 16, 2008 | 01:32 PM
dsickles's Avatar
i checked at o reilly auto parts and they didnt match up. the part numbers there are generally the same even for different cars. but i may be wrong
Old Jan 16, 2008 | 01:51 PM
fsttyms1's Avatar
thats why said to look at the 98 to 02, as the 03 is a different car. and to hold the 2 up and compare. the 03 may very well be different
Old Jan 16, 2008 | 05:17 PM
Situation is that someone has a high amp alt for sale pretty cheap and he had it in a 2003-up Accord. It will also fit 04+ TL's if that helps?
Old Jan 16, 2008 | 05:59 PM
Pictures on post #10
http://www.caraudio.com/forum/showthread.php?t=284442
Old Jan 19, 2008 | 07:24 PM
99TLhot's Avatar
Yes 98-02 accord alternaltor will fit on 99-03 TL
Old Jan 19, 2008 | 07:30 PM
99TLhot's Avatar
i have a 99TL and i try to buy a 150-200 Amp Alt, and i call every auto part dat i know and they sai not thing for that vehicle and when i try to call one place they say yes for 150amp Altornator for 99 TL, but when i pick up the altornator the box say it for 98-02 Accord, well i when home and install it. And guess wat? it FIT! . but you have to buy a new Bell Tho it cost another 20 buck at autozone.
Old Jan 19, 2008 | 07:33 PM
99TLhot's Avatar
There is a problem when you put in an high amp alternator tho. while you driving in a local road you'll see the battery and the brake light flash on your dash. it is ok dat it flash and goes out like 5 seconds. but when you drive and the hight way it not gone flash
chrisr
Dec 4, 2015 02:17 AM
Rob144
Sep 21, 2015 08:18 AM
datadr
Sep 12, 2015 09:12 PM
Phambam12
Sep 6, 2015 06:57 PM
nuldabz
Sep 3, 2015 05:49 PM
