air vents
Old Dec 2, 2006 | 01:41 AM
vzuptnguyen's Avatar
B A N N E D
air vents
when i turn on my heater.
air only comes out of the far left vent and far right vent of the car
the one above the navigation and then one above the glove compartment switch has no air flow coming out.
also, the 2 small ones at far end, on top, dont have air coming out either.
if anyone might know but doesnt know which vents im talking about, request and ill take a picture.
Old Dec 3, 2006 | 05:24 PM
B A N N E D
anyone? mods?
Old Dec 3, 2006 | 06:13 PM
Billy Sacco's Avatar
Kilos of yayo in
If your climate control is set to auto it usually only comes out of those. Try switching it to the position that shows the guy in the seat with arrows pointing at his head and feet and that usually activates all of them.
Old Dec 4, 2006 | 12:03 AM
B A N N E D
yea, its actually none of the options
does ur come out of all 4 vents on dash?
also, even if i press "off" on the panel, it doesnt turn off till i press it on the navi. weird.
Old Dec 4, 2006 | 09:13 AM
SBUtypeS's Avatar
DECEPTICON
Mine does the same thing. when I hit the "off" button on the console it still flows out of the dash vents slightly. However, from what I remember, it only occurs when I am using the "Auto" mode and not when I turn the heater on through the Navi screen.
Old Dec 4, 2006 | 09:45 AM
fsttyms1's Avatar
is it set to vent or something else. The only way it will come out of "all" the vents are if its selected to. (a arrow pointing to the head) Heat should come from the floor. The 2 side vents blow a slight bit to help keep the windows defoged
Old Dec 4, 2006 | 03:57 PM
Trackruner228's Avatar
Mine was doing this to on the auto mode but once its got the arrows pointing to the head or head and feet it works fine. At first I thought it was a problem but then I figured it out.
Old Dec 4, 2006 | 04:25 PM
fla-tls's Avatar
On the way!
Sounds like defrost mode. In that mode, the outer two vents work, and the defrost vents work. The middle and lower ones don't.
Silly question - is it set to defrost? The whole - won't turn off until you select it on the navi makes no sense. There is no off selection for A/C in the navi.
Old Dec 5, 2006 | 01:04 AM
B A N N E D
i use the "head depiction one only, as well as all of them. still no work
i did remove and reinstall the dash couple times, but im sure the air ducts are secure and arnt flimsy.
weird.
Old Dec 5, 2006 | 02:24 AM
oVerBoost's Avatar
HELP!
weird.
make sure the plug to the AC unit is plugged in all the way
Old Dec 5, 2006 | 09:04 AM
fla-tls's Avatar
On the way!
I dunno - it sounds like your mixer doors aren't moving for some reason.
Did you check all of your fuses?
Old Dec 5, 2006 | 03:22 PM
B A N N E D
nope, there are fuses for mixer door?
maybe just bring it in acura. =/
winter is here and mountains are cold.
Old Dec 5, 2006 | 04:38 PM
CJITTY's Avatar
Ackniculous One
Without going to my car to look, are the vents turned off using the manual rotating dial next to the vent itself? May be silly, but worth a look.
Old Dec 5, 2006 | 08:29 PM
TLsMD's Avatar
WINNING
I have tried but i have no luck turning my rear vents off???? helppp
Old Dec 6, 2006 | 12:39 AM
B A N N E D
im sure there are dials for the one above the radio, as for the passenger side. the dial cnotrols the far right, not sure about the left one
as for the "arrow point to head" i press that and leave it for like 10 minutes but it still doesnt do it.
i think its something with the ventducts itself.
Old Dec 8, 2006 | 10:22 AM
B A N N E D
and the heat comes on by itself every now and then even though everything is off
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
12vancover
Oct 16, 2015 12:04 PM
hashbrown
Sep 29, 2015 12:13 PM
