Air flow issues
Old Dec 4, 2009 | 02:37 PM
Aedin123's Avatar
Air flow issues
Ok so I have replaced my cabin filters but still have poor airflow in the car thru the vents. With the fliters and seal off the came out of the filter compartment very strong so i know the blower is good. I did notcie tho that when i try to change the area that air comes out of (vents, defrost, floor ect) nothign changes. I am thinking there must be something that directs the airflow that is broken or stuck. Can someone give me an idea of what that is called and how I might get to it to find out if its broken? Thanks!
Old Dec 4, 2009 | 06:54 PM
Aedin123's Avatar
I guess maybe I am the only one to ever have this problem
Old Dec 4, 2009 | 07:54 PM
FirePR2002's Avatar
bringin lead
damn dude - give it some time (more than 4 hours on a Friday). we don't come to the forums to answer your questions exclusively.
most likely the mixing motor/actuator.
Old Dec 4, 2009 | 11:48 PM
Aedin123's Avatar
eh sorry Its just really cold in Wisconsin and it would be great if I could get my defroster to blow some air. How would I get to the motor/actuator to see if it is the issue?
Thanks for your time!
Old Dec 5, 2009 | 10:48 AM
01tl4tl's Avatar
try using the search feature for blower motor and there should be several threads with actual help
I know that changing the direction of air with fan on high speed will contribute to the problem of a door mechanism breaking
most have a plastic gear hooked to a metal rod- like door locks work
do you have the dash controls for temp/direction or the Auto temp system that comes with the nav cars
you can remove the filter again and look to the left for control doors
Old Dec 5, 2009 | 10:50 AM
01tl4tl's Avatar
to clarify- you had a low flow prob first- replaced filters- what brand and did you confirm correct direction on install?
and still have the same low flow?
Old Dec 5, 2009 | 11:05 AM
FirePR2002's Avatar
bringin lead
I see you are relatively new - 1st thing is to get your hands on the service manual - do a search, it was posted in a thread for download. Huge ass file (800 MB and 2200 pages) but worth the DL. Also, familiarize yourself with the search feature on this site - it can sometimes be shitty, so do a google search with your key words and add acurazine.com.
check the last couple of posts in this thread: https://acurazine.com/forums/showthr...hlight=air+mix
the thread said to do a search for "heater" to find another thread with instructions to diagnose using the control panel.
this thread may help you also: https://acurazine.com/forums/2g-tl-1999-2003-98/heater-ac-issure-99-tl-572434/
also, i see tom is reading this thread - he might offer some advice also (damnit - he beat me!). good luck!
Old Dec 5, 2009 | 10:50 PM
01tl4tl's Avatar
yeah- but I havn't been inside the TL dash to be of much help beyond basic auto assembly methods
did you see the new acura tech page- replaced the free owner book link--
can you say bend over?
but in this case in may be worth a 3day for the actual info
https://techinfo.honda.com/rjanisis/logon.asp
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Sep 14, 2015 10:48 AM
sputik
Sep 7, 2015 01:40 PM
dlknight
Sep 3, 2015 07:54 PM
