after start engine stuck at 5000 rpm, cant shift out of park
Old 10-22-2005, 12:32 AM
Pete's2000TL's Avatar
2000 tl with 117,000 miles
After flooring the accelerator to go through a yellow light, i was unable to slow down. I tried braking but the rpms stayed high, finally i threw the car in neutral and turned it off after i safely exited the road.
When i go to restart the car, it revs up to 5,000 rpm and i cant shift out of park.
When i turn the ignition on both the d5 and p lights come on. The carhad to be towed home and i got hit with an $85 bill.
The battery was disconnected (to reset the computer?)
and WD40 was sprayed on the wire cable connected to the accelerator and it seemed to fix the problem.
The D5 and P lights still come on with the key in the ignition, when i start the the car d5 goes off and the red P light is on.
any concern with the D5 light coming on (i never paid attention before and just noticed it now)?
how can i thorougly clean the accelerator wire cable?
thanks in advance
Old 10-22-2005, 12:45 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Id be more concerned about the throttle being stuck the way it was. How does the tranny shift? Normally? So the D5 light still comes on after the battery had been undone to reset the comp? Does it blink?
Old 10-22-2005, 01:00 AM
battery was undone for 15 minutes, i had to reenter radio/navi codes
as far as i can tell the tranny shifts normal and its the original
no d5 does not blink
Old 10-22-2005, 03:06 AM
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
The TL your first automatic-transmission Honda product?
When you turn the ignition, the gear position indicator in the gauges will light up the current gear (P) and the recommended gear (D5). It's designed to do this. D5 will immediately go off after a few seconds or after you start the car.
All my automatic Hondas have done this, even back in the days of my 93 Accord. I'd turn the key to accessory and (P) and (D4) would light up and then D4 would go out.
Old 10-22-2005, 08:55 AM
soccerbenk's Avatar
u shud check ur throttle cable from the pedal to the engine, this happened to me once and my throttle cable just ended up being stuck on something in my engine bay
Old 10-22-2005, 09:45 AM
I need 2 more gears
sbuswell's Avatar
clean throttle cable with air intake and TB cleaners and also clean your TB while your at it. It is very easy to do and should help you a lot.
Old 10-22-2005, 01:36 PM
'99 Acura 3.2TL
@cUr@-TL's Avatar
yeah just check/clean the cables real good, and check/clean the TB too, maybe something's stuck in it (would be surprising, though)
'99 Acura 3.2TL
@cUr@-TL's Avatar
oh and a vacuum leak could make the engine rev up, too...
Old 10-22-2005, 03:18 PM
Petrie1997's Avatar
exactly how it happened to me. i floored the car to pass up another and then couldn't slow down. i was able to brake and shift into neutral and finally shut off the car. open your hood, get some throttle body cleaner and clean the throttle cable. spray some more cleaner and move it around (engine off) and make sure it isn't sticking. this solved my problem.
good luck!
peter =)
02-25-2020 09:57 AM
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
ninersfgiantsfan
09-09-2015 01:14 PM
HeloDown
09-08-2015 06:51 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: after start engine stuck at 5000 rpm, cant shift out of park
