Aem Big Brake Kit
Aem Big Brake Kit
i have seen that the accord v6 aem big break kit fits our tl, big break kit as in the rotor and the extension caliper thing...anyone know of any who has this and how it works? i have seen it on ebay for like 300-400 bucks for the front looks tempting anyone know please let me know
JON LERD
JON LERD
thats someones tl here is the link to their page can he or anyone who has it comment on it and the install?
http://community.webshots.com/album/37638241IdMtKO
I did a search earlier and found that the tl brake rotors are 11.8" and the accord's are 11.1", the AEM OEM brake kit rotor is 12.4". You would definitely need to use a bracket to extend the TL caliper further out. If you look at the pic you posted, there's quite a lot of un used rotor area used (silver area vs. yellow area). It's probably because that person used the bracket for the accord. If you want to maximize the brake area, you would need to shorten the bracket to match the different spacing from the tl to the accord... I hope this helps.
Originally posted by Bitium
That is just the rotors. The whole point of the big brake kit is pretty much eliminated. Like thescoundrel said, you are only using about 3/4 of the rotors, and still using the stock 1-piston calipers. What did he do with the 4-piston calipers or did he just buy the rotors?
the aem big brake kit is not the full blown caliper kits like brembo...its suppose to help stopping distance by giving the stock caliper more leverage when stoping....the reason why the stock caliper doesnt fully wear down the aem rotor is because the stock caliper is moves away from the center so much to fit in the new aem rotor....although only parts of the rotor wear the brake is improved and the rotor look phat.....thanks for your input guys
you are talking about the AEM "O.E. Caliper Big Rotor Brake Kit"
I was talking about the AEM "Four Piston Caliper Big Rotor Brake Kit"
ooopps.
Sorry for the misconfusion
ooopps.
ooopps.
InFaMouSLink
Oct 27, 2015 06:51 PM
nuldabz
Sep 3, 2015 05:49 PM
