Advice On engine
Old Nov 14, 2013 | 12:39 AM
bob441's Avatar
Advice On engine
Ok so I bought a car that was supposed to have a BROKEN timing belt but on inspection the belt has 4 sheared teeth and the timing itself is 2 teeth off what is the chance of having bent valves ??? i have another timing belt kit to throw the belt on and try it but i would like to know my chances thanks bob441
Old Nov 14, 2013 | 07:09 AM
3.2TLc's Avatar
The chance of potential engine damage is very possible and most likely will require further inspection to diagnose the severity.
Old Nov 14, 2013 | 08:38 AM
victus1's Avatar
I assume you drove the car after you got it. Did you hear any tapping valvetrain noises when driving? If not, it's probably fine. And don't rev up the engine to see if you can hear them. Change out that timing belt asap. Oh, and you need to replace the water pump, hydraulic tensioner, idler pulley and tensioner pulley while you're at it. You can get all of these oem parts in the Aisin kit.
Old Nov 14, 2013 | 09:21 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Its a time bomb get it replaced asap I could imagine its stalling and not idling right. If its not noisy then its good go for it.
Old Nov 14, 2013 | 06:23 PM
Skirmich's Avatar
I believe 2 teeth off should not be an issue.. that's like the normal advancing or slowing timing offset.
Old Nov 14, 2013 | 09:58 PM
bob441's Avatar
thanks for the responses guys I am trying to get the balancer bolt out now LOL. got the tools just cannot break it loose looks like it is original with 185000
Old Nov 14, 2013 | 10:40 PM
ErickUa5's Avatar
Mr.Helpful Diagram
If its the crank pulley you can get that bolt out with the starter just make sure to use a hardened 19mm.
Old Nov 15, 2013 | 04:50 PM
BetterBob's Avatar
I'm pretty sure momentum kept you safe. I would replace the damaged parts ASAP though. That's not something you want to dick around with.
Old Nov 16, 2013 | 08:27 PM
01tl4tl's Avatar
I can say based on many user reports,,the belt breaks slips or otherwise comes out of time = bent exhaust valves
this is a zero clearance engine,,when an exhaust is open it will hit the piston top and bend the valve stem = wont seat
many shops will say replace the belt and then we will see...and its always bent valves
so they get to charge another 1000!!
You have to undo most of the work you just did!
while intake is off, perform egr pathways and port cleaning to it
Soul_Deamon
Nov 13, 2018 04:44 PM
BobbyGraham388
Oct 22, 2015 05:05 PM
lilian_rz
Integra
Oct 18, 2015 01:17 AM
BigJilm
Sep 21, 2015 08:32 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
