Accessory drivebelt tensioner removal
Hello, I own a 1999 Acura tl and I would like to know if there are any "diy's" or instructions on how to remove the accessory drivebelt tensioner? Thank's...
Remove the belt > Remove the 3 bolts holding the tensioner to block > done!
It's relatively easy to do it but the space is tight! Don't be afraid to get into it, it's pretty simple.
Claaaaaaasic~
look in the DIY section, everything we know how to do is there,,well most of it~
link is at bottom of main page after sign in - look for Off Topic as section name
It is not hard to replace tensioner, but problem is the space to remove the middle bolt. You will have to do it through the wheel well. Don't remove the belt first. First is to try if you have a way to remove those 3 bolts, once you have the plan in mind, then remove the belt and proceed. That way you don't have to put the belt back and drive to the store to get tools or whatever you need if that is your only car.
^^^ Spend some time learning how to utilize the site's "Search" feature. It's all in here !!!
shamal (12-13-2014)
This is the thread I was talking about with the pics gone, from the New official page, it's that image shack site, I'm gonna post some so others will have a better pictorial experience
https://acurazine.com/forums/second-...ogress-643700/
3.2TLc (12-13-2014)
Very thoughtful.....thanks for taking the effort and time to help others.
Unfortunately, as our cars are getting older.....so is the hosting for pics within the "DIY"s.
