Access to top AT solenoid
Old Aug 6, 2023 | 04:46 PM
weitau's Avatar
I'm trying to get access to the top transmission solenoid and it's tricky to get around this connector (circled in red).
How do you remove this wiring connector from the metal bracket?
Anyone have ideas? I've pushed and pulled that tab on the connector and it won't budge.
I've also tried to unbolt that bracket, but it has a mess of stuff connected to it and they don't want to come off.
Old Aug 6, 2023 | 05:53 PM
Those can certainly be a PIA.
All I can suggest (which sounds like what you have been doing) is to use a small pocket flat screw driver and either pull up or push down on the (yellow circle) tab while simultaneously pulling / wiggling the grey connector in the direction of the green arrow.
In addition, if you can get a small mirror down there, look under the grey connector to check if there is another hidden 'tab' that may need to be actuated?
Sometimes that is the case and one would not realize it.
Good Luck!
Old Aug 6, 2023 | 08:26 PM
Jon M's Avatar
It is a royal pita. I wound up breaking the tab, but here are a few pictures with it off.
Old Aug 7, 2023 | 02:12 AM
whitetiger5's Avatar
i clean it up of any loose sediment with contact cleaner spray, followed by a little spray silicone. push on the tab and apply a small amount of twist to walk it out.
inserting a wide screwdriver in the areas marked in red and twisting helps too.
Old Aug 8, 2023 | 04:20 PM
weitau's Avatar
Sounds like there is a way to get this off the bracket! LoL
Appreciate all the suggestions. Will give it a shot!f
M-TL
1G TL Problems & Fixes
22
Aug 18, 2023 08:57 AM
jdjohn84
Dec 2, 2017 08:29 PM
150mph
2G CL Problems & Fixes
Jul 12, 2015 05:57 PM
96TL
72
Jun 5, 2011 09:41 PM
bo0sty
1G TSX Problems & Fixes
Apr 13, 2008 11:04 AM
