How do i remove these wires
Old Apr 12, 2008 | 04:51 PM
bo0sty's Avatar
so i just purchased some angel eyes and about ready to install them just need a simple question answered, how do i remove these pins from the plug. heres what the plugs and wire look like.
Old Apr 12, 2008 | 06:29 PM
feuss2's Avatar
10001110101
If you have a mini screwdriver set, the smallest flathead can probably be used to release the pins from the plastic...
Old Apr 12, 2008 | 07:17 PM
slickrab's Avatar
RGSTRD TL & TSX Offdr
A tiny flathead to push those tabs in. Make sure that you line the bottom of your screwdriver to the bottom of the tab. Those tabs will crack-off at the joint of stressed.
Old Apr 12, 2008 | 09:46 PM
CGTSX07's Avatar
why do u need to remove them?
Old Apr 12, 2008 | 10:58 PM
bo0sty's Avatar
cause im a perfectionist, theres 3 ways to install the lo beam angel eye according to pergines DIY.
can anyone go a little more in depth, not quite understanding. do i go from the pin side or the wire side where is the clip.
ill give some one a dollar if they find a youtube demonstration
Old Apr 12, 2008 | 11:11 PM
MMsTSX's Avatar
JDM Addict
http://www.youtube.com/watch?v=P-q0SVALfus
it's not very in-depth...
Old Apr 13, 2008 | 12:33 AM
bo0sty's Avatar
lol i meant on how to remove the wire from the plug. this is the only thing im waiting for before i install them.
i've watched that video plenty of time already
Old Apr 13, 2008 | 12:55 AM
slickrab's Avatar
pin side. there are two tabs for each pin so you need something like a needle nose plier to pinch from each end and than pull from the wire side.
Old Apr 13, 2008 | 11:04 AM
CGTSX07's Avatar
are there tabs holding them in? if not, just pull them out. if so, follow everyones recommendations above.
Jul 16, 2017 07:33 AM
dainmezron
Oct 16, 2015 06:56 PM
SUPRMN84
Oct 7, 2015 09:46 PM
lowgrowl
Sep 26, 2015 05:18 PM
