Instructions to remove yellow foglight covers
1. Unplug the bulbs. You have to squeeze the little tabs on the plug and then pull it off.
2. Remove rubber weatherseals.
3. Remove the bulbs. Look closely and you’ll see how they come off. Its easy.
4. Look inside the foglight housing. You’ll see 2 philips screws, one on the top, and one on the bottom. Remove the bottom screw and loosen the top screw. If you take out the top screw it will be a pain to get back in.
5. Pull out the whole foglight assembly.
6. Twist off the yellow cover.
7. Re-install. Done! Good luck!
This is for information only and IS NOT to be used for any purposes other than described.
crimping the 2 wires
I printed your intructions and your pictures. You know the whole Red wire w/siver dots and Blue wire with red stripe thing. BUT, I have 2 wires with silver dots. One has single dots every so often. and the second one has 2 dots be side one another every so often. HELP !!!
Re: Instructions to remove yellow foglight covers
hey guys..i was wondering... are you talking about the yellow glass bulb covers inside the headlight? if so...can i buy a set off any of you guys. email me at dmxstylez@aol.com thanks~
okay kewl i finally got them off today.. however after taking out one of the condoms and then getting to the other one i foudn that one of them shattered and broke into pieces.. so there are little yeloow pieces floating around in the housing.. do u know how to take off the headlight so i can get these pieces out??? is it even worht my time to do this??
Originally posted by OC2.598
How can I get one?
How can I get one?
Just kidding. www.value-caraudio.com Its made by Value Sports. Cost me $500 for the wing, $90 to ship, and $400 to paint & install. :wow:
By far the phatest wing around for our TLs. Now if I see a pic of my car without it I hate it.
does anybody know some sites where I can order the new style wing without the rear tail light for less than 565.00? Value-caraudio.com sells it for 565.00!! too much I think.
I also have a stock rear trunk wing for sale, its in pearl white ...thanks..
ok, 96TL this is for you..
thanks for the reply on the wing question.
I just received my after market tailights for my 96 3.2TL, now I want to remove the orange lense in side the housing, I was able to remove the internal clips holding the orange lense, now I need to take it out of the light housing, I don't wanna mess up the seals. thank!!
Where did you get aftermarket lenses? I assume you mean the Inspire tails from Japan?
Anyway, to take out the amber chamber is VERY VERY hard. You need to open the tailights by heating up the seals (its epoxy) with a heat gun and prying them apart. Be very careful while doing this, especially on the one fragile bottom corner that faces the quarter panel. I posted long instructions on this site. Just do a few searches. I’m warning you though, its very easy to break them. Do this at your own risk.
96TL yes my friend you are right indeed.. I now recall that long instruction posting, you put up quite sometime ago. I think I will just break the amber piece internally, since I took it off the clip holder and then just shake out the peices, rather than mess with the seals.. I don't want the risk of water penetration.. Thanks.. and yes the are the inspire lights..
try using a dremel tool
'96 TL Where/ How did you get the Taillights cleared like that? And does anybody know of an online seller for clear FRONT bumper lenses?? Havin a hard time findin them, 'specially up here in Canada!
You can get the Inspire Tail lights on ebay or overseas. Or here on acura-tl.com. I bought mine on ebay, and then you have to use a tool to get the yellow circle out. Really easy to do. Also, look on ebay for the front clears. Thats where i bought mine.
yellow fog light covers
I, too, am interested in buying one or two of the yellow fog light covers, if anyone wants to sell one or both of theirs.
jacobs7803@cox.net
thanks!
jacobs7803@cox.net
thanks!
