abs sensor problem
Old Dec 26, 2022 | 05:22 PM
mikes black ac's Avatar
abs sensor problem
2002 tl-i had ordered 2 front left abs sensors by accident not knowing i had already ordered one already some time before and wasn't able to return the extra one.i fixed the one wheel issue everything was fine.then during the summer i had the tcs/abs light come on again but now it was for the right front side.i found the damaged wires and used the old bracket for the right side and made it connect to the arm. i cleaned the deep grooves on the tone wheel with a screwdriver to get all of the corrosion out and lightly sanded the high grooves,sprayed brake cleaner on,wiped the sensor head off and blew it with compressed air, put the wheel back on,drove it for so many feet and the lights went off and remain off but now i have another problem.when the car comes to stop the last 5 mph and less the abs engages and pulsates the pedal and makes it harder to stop completely.it only happens at that speed.could using the wrong side sensor cause this or the tone wheel scraping/cleaning do this?.i fear that in the snow or on ice that it will cause me to skid further and cause an accident.it's very weird..any ideas? thanks.
Old Dec 27, 2022 | 02:31 AM
Jon M's Avatar
Mike, Magnetic Sensor is probably loose or not seated all the way.
Here is a link to a thread from the past. https://acurazine.com/forums/2g-cl-f...g-stop-487184/
flyromeo3
Oct 21, 2013 08:20 AM
03CLS6spdcharcoal
1G CL Problems & Fixes
39
Apr 15, 2010 12:17 AM
tlmadness
1G TL Problems & Fixes
Aug 14, 2007 10:26 PM
sebounet2005
Jun 25, 2006 08:25 PM
esco786
Feb 17, 2006 12:06 PM
