ABS Problem
Old Feb 16, 2006 | 03:11 PM
esco786's Avatar
ABS Problem
Been having ABS problems in my 2.5 TL since 160000km. The light illuminated and the accumulator would make the buzz sound too often even after the car started. Sure enough, the ABS code (1-8) showed accumulator to be the problem. After $300 of replacing with a new accumulator, the buzz sound comes on after turning the car for about 15 seconds and then the ABS light clicks back on. Anyone know what this could be or had a similar problem
Old Feb 16, 2006 | 05:14 PM
vishnus11's Avatar
did u bleed the accumulator and the ABS system after putting it in?
Old Feb 16, 2006 | 07:58 PM
TexasHonda's Avatar
Code 1-8 is a LR wheel sensor electrical noise or intermittent interruption. Who told you the acccumulator was at fault? A $70 shop manual is a lot cheaper than a $300 accumulator replacement.
I would suggest removing the wheel sensor, cleaning the sensor, and cleaning the cogged wheel beneath the sensor. Insert a rag in the sensor opening and turn the wheel to clean the cogs. Dirt/grease can accumulate and interrupt the voltage output of the sensor coil.
good luck
Old Feb 16, 2006 | 09:14 PM
FastHarry's Avatar
might have to do with the power booster, how does the pedal and breaking feel? Any breakin problems or just the noise? ill also check the TSBs tomarrow also.
Old Feb 17, 2006 | 02:32 AM
esco786's Avatar
well the accumulator was leaking at the base (eventually it had rotten), and also the noise from the accumulator would come almost everytime hard pressure is appleid to the brakes. i did bleed the system as well with a pump.
Old Feb 17, 2006 | 08:49 AM
vishnus11's Avatar
good luck
but how come he's hearing a buzzing sound from his accumulator. If a sensor was at fault, why would the accumulator react in such a manner?
Old Feb 17, 2006 | 12:06 PM
TexasHonda's Avatar
He may have the wrong code. I agree that ABS pump run-on is not caused by LR wheel sensor.
An accumulator leak can usually be fixed w/ simple replacement of the small oring that seals accumulator to the modulator.
Accumulator oring is not available from Acura, but you can match at an auto parts outlet. That fixed the replacement modulator I found for my daughter's 2.2CL. Original modulator had an internal leak that I couldn't fix.
The 2.5TL has a different ABS modulator than the 2.2CL, and the 3.2TL.
regards
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
