99TL Upgrade To DVD-ROM Help!!!!!
I just bought a DVD-ROM for my 99TL that came out of a 2003Tl. Upon installing the unit in the trunk and plugging it in I get no sign of power when I turn the car on. I have the code also, is there something Im missing here maybe I need to unplug the battery cable or should I just assume that the unit I bought is bad?! Help all that have recently gone through upgrades please!?!?!?!?!
I've never done this myself but everything I've read indicates that the DVD unit is a Plug N Play replacement for the hard drive based unit used in the 1999 TL.
Are you sure that it was taken from a 2003 TL?
Check the model numbers against those listed on Paul Mooney's helpful navhelp.com site:
http://navhelp.com/other.html
Was your stock navigation unit functioning properly? If so, you might want to hook it up again to confirm that it still works. Maybe you blew a fuse.
Do you get any sort of message displayed on your nav screen?
Do you have any sort of warranty on the part?
Bob
Bob
make sure all the connections are tight - one of my wires was kinda hard to connect to the DVD unit when I put mine in. If it works and you connected everything right, it should turn right on.
Bob
Bob
Originally Posted by y2kardell
Everything is hooked up correctly, I even plugged in the old unit and the screen came right up. Worst case scenario if this thing is bad, anybody knows how much it takes to repair one and is there a national center that repair these units?
Originally Posted by INSPIRE 32V
well when i bought by 99 it already had the dvd rom and also had the 04 dvdrom version already. but i am pretty sure that your dvd rom box is bad.
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-30-2015 09:43 AM
kb1rl
09-30-2015 10:17 AM
