6 Speed swap questions...
OK I plan on doing a J32A2 swap into my 01 TL-P within the next year or so and I already know what I need for that swap.. Engine harness, TL-S auto ECU and gauge cluster... BUT I've been thinking it over and I might as well do a 6 speed swap while I'm at it.
My main concern is rewiring... What would I have to do to make my 01 TL-P function 100% properly?
Of course I'll need:
-CL-S 6MT engine harness
-CL-S 6MT ECU
-CL-S gauge cluster?? (not too sure on this one)
What else would I need? I can't seem to find a good DIY for the 00-03
-CL-S 6MT ECU
3 pedals in my 99 TL
Check the 6 spd swap threads in the 2g diy section. You need a lot more than just wiring.
But, are you planning to keep the tlp motor or go with the 6 spd type s motor cause that would make a big difference too. Then youd need the richie module if your keeping the p motor and if not then youll be fine with the 6 spd ecu from the cls. Check kris (fsttyms1) 6 spd thread at the end of it he lists all the parts you need for it.
I plan on going J32A2 Type s motor with a 7th gen accord transmission.
Also, kris (fsttyms1)'s swap was with a 99... The wiring is completely different than an 00+.
As far as I know, a J32A2 is plug and play to any 00+ TL-P with just engine harness and ECU. The 99 Is harder cause it has the 4 speed trans
Unregistered Member
i am aware of all the engine parts needed. I just need some info on wiring and such.
mlody
12-04-2019 02:11 PM
joflewbyu2
10-08-2015 11:16 AM
xsilverhawkx
09-28-2015 06:51 PM
