6 speed conversion, 2nd problem 9/2/17
#283
Ok Ill be test fitting tonight. Ill post what i find and pics later.
So NSXNEXT hopefully you can hold your pants on that long
#284
Received 1,080 Likes
Can't f'in wait.
#285
Maybe ill post the results in the AM
#287
hahahaha Ill get teh results up tonight
#289
Originally Posted by ProvidenceLeaf
Give me directions! I'll be there in a few hours!
#293
Ok well i mounted the tranny to the engine and set it in the engine compartment to test fit for clearance. I need the bolts to the mounts that im missing to get it to sit accuratly in there but its extremly close right now (have slightly smaller bolts slid into place on the tranny mounts on driver side).
It sits higher than the TL-P motor by quite a bit
BUT
It fits.
Im not sure how much the engine rocks under load, but there is around 1/2 inch min at its closest, of clearance across the intire top of the IM. Now i dont believe that the plastic engine cover will fit with out hitting? and im not sure if the hood liner will fit. I guess ill find out down the road wether it hits once i can start driving it.
BUT
It fits.
#296
Kris, gotta go feed the baby. Awesome work. Thanks for the effort. Hopefully you're feeling better. Let us know what else you find out.
Would love to see if the TypeS intake manifold bolts onto your old engine.
#298
#299
Oh and i dont remember what the stock wheel well gap was before the swap but its now a ridiculous atleast 6 finger gap
#300
Originally Posted by htown
What kind of parts are you waiting on now? What's left?
#303
Originally Posted by MikePA
Time for a shaker hood?
#305
Got shipping/tracking confrimation today. Stuff will be delivered thursday. Any good luck it will be the clutch and flywheel (should be at 62 lbs) then i can finally start the final install
#306
Why?? it fits under it. Plus a shaker style hood on a Transverse mounted engine would be the :ghey:
#307
Methinks you're going to need a "little" hood bubble on your TL now
Oh, and the trailer you used to pick up the engine is sweet... (no pics of the tow vehicle ??)
#308
and I quote, "Now i dont believe that the plastic engine cover will fit with out hitting? and im not sure if the hood liner will fit."
#309
Tow vehicle
and trailers (just for you Greenie)
#311
Originally Posted by blk2001tlon19s
I need a tow vehicle.
nice work! Going to try to swap out the harnesses this week?
#318
Originally Posted by Mike_McCready
Are either of you pioneers going to make a diy for us simple folk? I would love to do this, but lack the general knowledge involved
#319
PCM full of water, yummy
Kris, don't forget you'll have a higher redline with the type-s ecu/engine, so the tach won't be right (minor issue..) Will the yocal acura dealer flash your old key/ignition cylinder to the new ecu? Great job, I might have to head to the northwoods this summer just to check out your ride... unless mine falls under the knife also. Now that I have the ws-6 to rip around in, the tl has become a garage queen and it is getting more and more tempting to install a 6 speed, then I will have 2 6 speeds . later
