3 Magic Wires to Replace Help
I want my car to be electricly optimal. I'm adding a system and maybe fog lights... I have a Navi and a Radar detector.... In a 2000 TL.
So I'm going to replace or add to these wires with 4 guage... I don't know what's in there yet or how they look...
1) from negative battery terminal to chassis of the car
2) from negative battery terminal to engine block
3) from positive battery terminal to alternator w/ an ANL fuse
I hear this can drastically improve the flow of current...
Please let me know what we have stock and if this is an easy diy or how many feet I'll need if anyone has done this
Boomer SOONER
Doc, after looking at the wires, they seem to be 8 guage stock, at least the one that goes right to the chasis is (the one that snaps into the top of the coolent reservoir. But you can see them very easily if you look. There is another one from the tranny to the engine block that seems very easy to upgrade. I will do all for my car pretty soon cause 84k miles has taken its toll on my wires (they look like crap).
Boomer SOONER
Originally Posted by Doc Holliday
Hit them all with 4 guage
Well, radar dectector doesnt take that much power... maybe the navi takes more but that should be within factory specs. As for fog lights, that probably takes A LOT more power than the NAVI unit. You can just setup a relay harness system and it will bypass the 8 guage wire, simple and probably less than $10 to make. The relay harness will supply the fog lights with power from the battery for better current flow anyway. For this, even 12 or 14 gauge is good enough for just the fog lights. like 10 cents a foot and you wouldnt need more than 20 feet at all.
Check this post out
This is what I'm going to do... Just wondered if any of you guys have done it in our TL's?
http://forum.sounddomain.com/ubb/ult...5;t=007801;p=1
Former Sponsor
Good post. That's definately not professional thought. That Mustang underhood looks horrible. He way overdid the 2 gauge wire runs. Looks like somebody got a garden hose tangled up in his engine. This is an easy task. And pretty cheap to do. But I've seen more customers fox it up than I have seen successful. A shop should charge about $45 bucks to do this. (on most cars)
I've done it to all of my cars. It definately makes a noticeable difference if you have amps and such.
Where should I go to have it done professionally?
Where should I take it to have it done?
Former Sponsor
I could do it but, I'm not a real handy dude... I would take it somewhere for that price...
When it's done it should look clean. Almost factory. $45 bucks should cover labor. A fuse holder will run up to $30. 4 gauge cable should run $15. You should also replace your Battery terminal connectors which cost about $30 each.
I have an Accord in my shop right now from California. I showed the dude my TL under-hood. He spend over $150 just in terminals and cable. The prices above are just for starters. My Civic and TL have gun-metal ground feet. Gun-metal ring terminals. And sweet batt. terminal connectors.
If you got the funds.... Pay for the good shit. If you don't wanna spend that much.... The basics will still improve current flow and help with quick charge and discharge. Either way you are doing a good thing. Have fun man.
You are going down the right path, even though I don't have a giant system, this really improve the all around performance of the electrical system, including radio reception, as well as quicker throttle response. Note, I also replace the OEM lower block mount with a ZERO gauge wire. Here you go DOC...
And finally, you can check this thread out, very usefull information.... Grounding system
It's a very simple installation, should take you about a good hour, taking your time and doing it right.
Good luck!
I just want to buy all the stuff needed and have a professional do it...
For the positive terminal... I'm going to leave the stock alone, add a 4 guage unless you think I should go with 1/0, then one for my system, and do I need one for the fogs if I get them?
So that's 4, I guess on the positive terminal alone?
Then for the negative terminal I'll use the stock, add a 4 guage or 1/0, then what else?
What terminals do I need ?
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
alan_rich
09-07-2015 11:08 PM
