2003 TL Type-S known problems
Old Sep 23, 2011 | 07:47 PM
seeya1's Avatar
I already have a 99 TL and I pretty much know the major problems with this year. Tomorrow I'm going to look at an 03 TL Type-S and wondering what if there is anything specific I should look out for or be aware of.
Thanks in advance
Old Sep 23, 2011 | 07:51 PM
thewrangler99's Avatar
trans problems!!!!
Old Sep 23, 2011 | 08:01 PM
seeya1's Avatar
Originally Posted by thewrangler99
trans problems!!!!
What exactly is the problem? It has 84,000 miles on it.
Old Sep 23, 2011 | 08:48 PM
just search the forum or go to trans failure thread.... basically trans will die on you! whats the selling price?
Old Sep 23, 2011 | 09:07 PM
seeya1's Avatar
$6995 I've looked at about 20 of the 60 something pages and I'm not really finding anyone with the type-s replying but I don't know if they share the same trans.
Old Sep 23, 2011 | 09:42 PM
fsttyms1's Avatar
Trans problems are with ALL 2g tls (though the 99s were less problematic) The other issue is leaking rear main seal.
Old Sep 23, 2011 | 10:06 PM
seeya1's Avatar
Well that doesn't sound good considering my 99 tl trans has been acting up for at least 60,000 miles.I have to manually shift it and let off the throttle every time until it grabs the next gear.Does the 02-04 rl have the same tranny issues?
Old Sep 24, 2011 | 03:38 AM
Edward'TLS's Avatar
6G TLX-S
Read this :
https://acurazine.com/forums/2g-cl-transmission-recall-q-55/
2G CL and TL shared the same tranny.
Old Sep 24, 2011 | 04:37 AM
Karanx7's Avatar
Unregistered Member
The RL never had any trans problems, if I recall correctly.
Old Sep 27, 2019 | 02:19 AM
Jack lape's Avatar
6th Gear
I had trans isues also upper intake manifold gets gummed up
Just remove plastic covers to engine then square plenum cover Clean out the Grooves with degreaser or intake cleaner dont damage metal gasket replace be sure not to flip gasket wrong way or youll block off The air flow reinstall metal gasket and tourque to specs this will improve response throttle and Mpg too
drillzzz
Jul 28, 2019 06:30 PM
james357
Feb 13, 2016 02:37 PM
Ponsey_Scheme
Oct 23, 2015 09:16 PM
Azonics
Sep 22, 2015 05:28 PM
