2003 TL Factory subwoofer out
Old 12-06-2015, 03:14 PM
Walfunk's Avatar
Angry 2003 TL Factory subwoofer out
Hey AcuraZine. Its been a minute, but my 2003 TL-S is still rolling (291,000 miles!!) Noticed my factory sub is not working...bought a replacement bose amp and woofer but still no sound. Was hoping I would not have to drop the headunit, etc..Anyone have any clue what the issue could be? The crossover in trunk maybe? The remote turn-on from radio? I don't know...Radio and four door speakers work fine. Maybe a fuse? (I could only hope.) I'm going back out now to check for power to harness, etc., but looking for any help. Tired messing with this thing....
Old 12-06-2015, 03:36 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
I highly doubt is the HU.. More likely the Sub Amp or crossover took a dump..
Have you tried testing for current?
Walfunk (12-06-2015)
Old 12-06-2015, 03:38 PM
01acls's Avatar
Check passenger fuse box-fuse#9.
At the sw amp.
Power wire is WHT/GRN. Careful some speaker wires are also WHT/GRN. LOL
Ground wire is BLK.
Trigger wire is ORN.
Old 12-06-2015, 03:41 PM
Walfunk's Avatar
Thanks Skirmich..that's what I was thinking, not the headunit. I replaced the sub amp and speaker but not the xover....hmmm...is that the black box hanging down in the trunk? I can pick it up from the salvage yard I got the other parts from today..thanks for the quick reply btw...
Old 12-06-2015, 03:42 PM
Walfunk's Avatar
Thanks 01acls! I was hoping there may be a fuse issue! Gonna check now!
Old 12-06-2015, 03:47 PM
Walfunk's Avatar
Not the fuse O1ACLS...like I said the radio and door speakers work fine...just sub is out...
Old 12-06-2015, 03:49 PM
Walfunk's Avatar
I'm thinking the xover. Gonna check for power to the amp, etc as soon as I can find my multimeter....bummed....
Old 12-06-2015, 03:57 PM
01acls's Avatar
The power wire to amp is hot 24/7.
The module at the right rear package tray is the antena coil not cross over.
Old 12-06-2015, 04:08 PM
Walfunk's Avatar
I see 2 small black boxes in the trunk. 1 says "tdk" which I know is an audio company and has a plugs on the left and right side...I take it this is the xover-correct fellas? The other box has no plugs running to it..no clue what that could be for...
Old 12-06-2015, 04:09 PM
Walfunk's Avatar
ohhhh..just saw your reply 01acls...ok, then....where is the crossover? I got the amp behind the passenger rear seat....
Old 12-06-2015, 04:11 PM
Walfunk's Avatar
Please don't say behind the dash 01acls!
Old 12-06-2015, 04:13 PM
01acls's Avatar
Lol there's no x-over back there. Prob build into the head unit.
Old 12-06-2015, 04:21 PM
Walfunk's Avatar
Thanks 01acls....I just read on a previous thread that xover is built into amp under rear seat...if that's the case, then I'm stumped because I tried another one today...still no sub...damn....
Old 12-06-2015, 04:23 PM
Walfunk's Avatar
clueless as to why no sub now...radio, door speakers ok...replaced sub and amp...still no bass....
Old 12-06-2015, 04:34 PM
01acls's Avatar
Is there power at the trigger wire... Orange color?
Or supply a hot to the orange wire to turn on the amp.
I think the amp is under the seat back (vertical) of the rear seats.
Old 12-06-2015, 04:36 PM
Walfunk's Avatar
01acls..that is correct...I replaced it but have not checked for power...gonna check now..
Old 12-06-2015, 08:25 PM
Walfunk's Avatar
of course my multitester which has been laying around for days is no where to be found...that's it...putting the back seats back in and hopefully a fix will show up here...thanks for all the help fellas...
Old 12-06-2015, 08:44 PM
01acls's Avatar
Assuming the replacement amp is good, then your next step is to:
1. Test for power to the amp, main power supply, if none then supply power to test for sound.
2. Test for power to the trigger wire, if none then supply power to test for sound.
3. If still no sound after supplying power to both 1 and 2, then supply a musical source to the low level speaker in terminal at the amp. Make sure the grounding wire is good at the amp.
Once all 4 requirements are present the amp will either work or not definitively.
The easiest way to supply a known good musical source is to use a CD player, phone, or mp3 pllayer via the headphone jack. Just go to a 99 cents store and buy a cheap head phone. Make sure that it works and then cut the ear buds off. Now stripe the rubber insulation off so only bare wire is showing, than plug the jack into the musical source (keep the bare wires separated) and connect the bare low level musical source wires to the amp's low level input.
After all this if it still does not sound then the head unit is bad or the low level speaker wires going to the amp is bad.
Old 12-06-2015, 08:59 PM
Walfunk's Avatar
Thanks o1acls! I will try next weekend...great suggestions...now, lets say there is no power at 1 or 2 of your list...how do I supply power? tap into what wires? or just run a wire from the fuse box?
Old 12-06-2015, 09:09 PM
01acls's Avatar
No power
Check the under hood fuses #41, 54, and pax fuse #9. If all fuses are good then you have a severed wire but you need to test the fuses for voltage to be sure. Don't just eye it and assume that the fuses are good.
Yes, supply power direct from car battery via a wire, even if its speaker wire just for testing.
It's a good idea to power up the amp and make it works to eliminate that part of the system and move on to something else.
Ahh did you testt he woofer to see if it works? That should of been the first thing you should of done, assuming it's an easy access to the speaker terminals from the trunk.
Old 12-06-2015, 09:21 PM
Walfunk's Avatar
Yup, tested the old and new woofer-they work...bought the 2nd one today for $8 as a backup....you say "under hood" fuses...under the hood? not the ones IN the car? the #9 fuse in the car is good...radio does have power...
Pinhook
12-03-2015 09:50 PM
Yehokhanan Jackson
1G TL (1996-1998)
11-27-2015 10:48 PM
Antonio K
11-25-2015 06:15 PM
Chris_Sittig
11-20-2015 07:57 PM
Quick Reply: 2003 TL Factory subwoofer out
