2000 TL heater core replacement
I need all the help I can on completing this job. I have the column dropped and the dash mostly pulled away but I need to know how to release the box that is holding the heater core. The box that holds the a/c condensor unit is also removed. Can someone please guide me to the finish line? This is starting to become frustrating to say the least.
Do you have the service manual? There is one readily available online if you search for "service manual." from what i saw there it appears that after you have properly recycled the AC refrigerant and disconnected the lines going into the unit, there are quite a few self tapping screws, bolts and nuts that hold it up in place.
Esanchez8701
Dec 6, 2010 03:36 PM
