Heater core replacement
Old Jan 12, 2019 | 05:11 PM
stickymatch's Avatar
3rd Gear
Hello,
The previous owner of my '08 TL used so much radiator stop leak that it clogged my radiator causing over heating. I am sure my heater core is completely clogged and I don't want to try and flush it just replace it. Is heater core replacement a "do it yourself" job or? Can it be done without removing the dash?
Old Jan 12, 2019 | 08:19 PM
https://acurazine.com/forums/third-g...-747304/page2/ this DIY might get you closest to a heater core DIY but I believe if you actually want to replace it, you'll have to tear out your dash. Hopefully you should be okay just flushing it; i'd probably try that before tearing out the dash but those who've actually taken apart their heater core can chime in.
Old Jan 13, 2019 | 01:10 PM
truonghthe's Avatar
use compressor air to blow out the blockage in your heater core, trust me you will have to tear the dash apart to replace the heater core.
Old Jan 14, 2019 | 05:30 PM
Iggy's Avatar
Old Jan 15, 2019 | 04:55 PM
Jason Converse's Avatar
Heater core replacement.
I have a leaking heater core and I was told 8.5 hrs labor. No way to do it without removal of dash. It's going to cost around $800 for me to have done. Flush it out if you can. Thanks.
Old Jan 24, 2019 | 11:08 AM
DMZ's Avatar
DMZ
Head a da Family
Not a cheap job by any means!
Paul, our star master mechanic here in Nawth Jerzy, recommends staying away from all that stop leak crap for this very reason. He's seen many a heater core go bad as a result, resulting in nice expensive work for him!
That's why I'm replacing my radiator next week which has a very very slow leak before I get stuck. I'd pay to have my car towed before I'd put Stop Leak in it, a far lower cost option to Stop Leak!
techtalk
1G CL DIY & FAQ
Nov 14, 2015 11:17 PM
Esanchez8701
Dec 6, 2010 03:36 PM
peicanada
1G CL DIY & FAQ
Mar 11, 2009 03:23 PM
