03 TL and 01 CL motor/trans the same?
Old Dec 13, 2012 | 08:56 PM
MS225's Avatar
I have a wrecked 01 CL and thinking about buying a 03 TL to swap my motor and fresh built transmission in.They look like a perfect match,but i wanted to double check.
Old Dec 13, 2012 | 09:45 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Yes they will both swap easily just make sure your not putting a base motor in a type s
Old Dec 14, 2012 | 05:02 AM
MS225's Avatar
The CL is type s and TL is base,so i'll be putting a type s motor in a base TL.It's just going to be used as a daily driver.
Old Dec 14, 2012 | 07:35 AM
fsttyms1's Avatar
It will work but you will need the S ECU and some wiring for the IMRC
Old Dec 14, 2012 | 09:06 AM
^ he should have te ecu and all the wiring from his wrecked 01 cl. All he should need is something to control the IMRC like the msd switch
Old Dec 14, 2012 | 07:25 PM
MS225's Avatar
This a tuff swap?
Old Dec 15, 2012 | 01:45 AM
3.2TLc's Avatar
Hey MS225, shouldn't be overly tough for a seasoned mechanic. The real advantage here is to have the donor car nearby. As always, the proper tools and understanding the task at hand will be the key to the overall ease and success of the swap. One suggestion would be to label things and have a service manual available.
If you've never done this before, either get an experienced friend to assist or sub it out !
Old Dec 15, 2012 | 05:54 AM
Karanx7's Avatar
Unregistered Member
Very easy swap. Another option is to just put in the type S engine and keep everything stock in the TL. The car will still think it's a base TL, but the type S engine will give some gains.
Otherwise, you will have to get a new ECU and wiring. The CL stuff might not work in the TL.
Old Dec 15, 2012 | 10:49 AM
MilwaukeeDave's Avatar
Having the cars side by side is a huge advantage. I'd strip both down of all the parts I needed out and was going in. That way before you start converting it you can take stock of what you have, give a thorough inspection of all the parts, and take the time to put it together carefully and correctly the first time!
Old Dec 15, 2012 | 02:34 PM
fsttyms1's Avatar
I would rather swap out the drivers side engine compt to cabin harness and use the stock IMRC controller.
Old Dec 17, 2012 | 09:09 PM
MS225's Avatar
I dropped the TL off at a buddys house with a shop yesterday.We will be trailoring the cl over there soon.Thanks for the tips.
Old Mar 20, 2013 | 11:26 AM
MS225's Avatar
UPDATE
Picked the tl up monday and its running strong.I had to get the acura dealership to make the tl ignition talk to the cl computer.Other than the the tcs light is on and either needs to be blead or swapped.
Old Mar 20, 2013 | 12:05 PM
assclown's Avatar
2000 acura tl FPR
Might want to end up pulling the TCS bulb if it bothers you. I doubt you'll get TCS working being that the type S has VSA.
Old Apr 25, 2013 | 05:34 AM
MS225's Avatar
It's been a month with no issues besides loose battery terminals.I just got off a long turnaround and just been driving it to the grocery store and gym.Its been hard working on this and my Camaro at the same time.
lastcall190
May 5, 2013 12:37 PM
crcendo
Jan 10, 2012 07:50 PM
Dblock0405
Jan 8, 2011 12:39 PM
sho_nuff1997
Apr 19, 2010 12:07 AM
TalontedTSi
1G CL Problems & Fixes
Jan 5, 2010 10:36 PM
