02 TL-S kinda hiccups from time to time
Greetings,
I have an '02 TL-S and so far it has been a hoot. I have about 14k miles, and the car was built in May, 01.
Anyway, from time to time, it just stumbles for just a split second. I can't tell if it's coming from the tranny or the engine. But, it always recovers quickly and I won't see the problem again for several days.
Has anyone else experienced this?
Could this be related to the tranny problem I've read about here? For those with tranny problems, what are the symptoms you have seen?
TIA
TIA
No, you are a dork.
I know exactly what you are talking about....it occurs most when i am lightly touching the gas at cruising speeds...doesnt seem like tranny to me...more like a computer issue........oh well. lets see what others say...
d
d
Hickup is a good word to describe this. I wanted to call it studder, but "studder" may imply something else. My original tranny used to studder under hard acceleration some time before it finally gave up and needed a replacement.
Back to the hickup - I have had this behavior since day 1. And it is reoccurring on the new tranny as well.
While I am cruising steadily at 50 mph (sometimes 45, sometimes 60), usually in the morning, about 5-10 minutes after I leave for work, the car does the hickup.
To me it feels like engine loses power. But it also may be something in the tranny. A couple of times I thought it felt like someone grabbed the brakes very briefly.
One time I caught a glimpse of the tach during a hickup and I saw the revs go down a bit.
To think of it, it also feels like bumping into the rev limiter in SS mode. Maybe the computer detects a false "redline" condition and momentarily cuts off the fuel?
Or maybe the plugs are misfiring?
Whatever the hell it is, it is quite annoying and ruins the experience of leasing what is supposed to be a great car.
5th Gear
Gas Petal? Will you should be gentle if you have a gas petal.
Does this hiccup occur when the engine is cold only - or at varying temps? Had a rental recently and we'd gun it when cold and could feel a slight hesitation as it rev'ed up.
Are you using a high octance gas? They say if you buy gas from the same place ALL the time that you will eventually have problems because you are taking a chance that that gas station sells clean gasoline - that's why it a good idea to get gas at different places - hope that makes sense.
Also check the air filter and air passage ways - perhaps you have an obstruction.
Just a few thoughts. Good luck with it.
Re: 02 TL-S kinda hiccups from time to time
Originally posted by kennelm
Greetings,
TIA
Greetings,
TIA
Hey guys.. maybe this'll help...
The "hiccup, stutter," or however you may want to personify the symptom may be the lock-up torque converter (if I'm interpreting your keen diagnoses correctly) adjusting to cruising speeds. If you refer to your owner's manual, they discuss the sensation of another "shift" in the transmisison as you begin to cruise at a highway speed (~45+ mph). Also, the car has the grade-logic software integrated into the tranny, as I'm very sure you're aware of, and this system is also tracking degrees of elevation as you cruise along, working not so harmoniously w/ the transmission, hence your "hiccup".
Here's something to try... drop it into SS, leave it in 5th gear while cruising around the speed your used to experiencing the stutter .. apply the accelerator intermittently and determine whether or not you experience the same symptom. Then drop down to 4th and repeat. Sorry to make this sound like a high school science project, but hell, if it's buggin' you, you might as well try to figure it out.
Best of luck,
Pete
Best of luck,
Pete
d
d
This is it exactly. Always happens on light throttle, and usually at slow speeds, say 30mph. Never really noticed it under hard acceleration. The more I think about it, the more it seems like an engine quirk vs. tranny quirk. Maybe a loss of ignition? Computer problem maybe. Anyway, it feels like the engine stumbles (or hiccups) for just a split second.
Can anyone tell me what the signs of the tranny problem are? What to watch for. I'd like to be on top of this before the warranty runs out, you know! Does anyone know if the May 01 cars are subject to this?
Nevermind on the tranny question. I found the thread.
Try driving in D4, that fixed it for me, I had the same exact problem, and of course it never happened at the dealership. I only go to D5 when I will be at or over 65mph for an extended period of time. I haven't experienced the problem ever since.
I have also noticed this in my 02 TL-S also. I think it is when the transmission goes into lockup, and a certain speed right when it is suppose to shift into lockup the transmission gets confused and does not know weather to shift or not so it hunts back and forth. I dropped my car off at Acura of South Florida to have my front bumper repainted and they gave me a loaner 02 TL, and that car alsohad the same symptoms.
Yeah, I think mine does the same thing. It's an 02 TL-S made in Jan 02. Does it happen right around 2K rpm? The whole drive-train just seems to kind of be on a "rubber-band" while cruising at that rpm. It's like people have said, I think it is the torque converter locking and unlocking. If you just barely hit the gas it seems to just kind of decide what to do first... then it sort of lunges or surges or next it feels like it downshifts and the brakes have been applied. Yes, I would say that I have noticed this effect in BOTH 02 TLS that I have driven. I don't like to be cruising lightly at around 2K rpm. It does feel confused at that speed/throttle setting. AND IT SEEMS THAT IT'S ALWAYS NEAR THAT SETTING. It's like it's got so much power that it wants to be unleashed and can't stand to be "hovering" around 2K rpm. Mine is smooth as silk when I'm acclelerating, or cruising at 3K rpm... Only problem is, I've got to be going 95mph to get it up to 3K rpm. Perhaps I should try the D4 routine... that might help it to feel a bit more solid, but at the expense of the gas pump
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Originally Posted by kennelm
Daryl,
cycdaniel
12-17-2019 10:58 AM
