00 TL - starting problem
Hey Griffing, this seems to be a rather common issue that unfortunately has never had any real resolution as to the exact cause. All that ya can do is make sure that the basics are covered. It appears that with the aging process along with ethanol enhanced fuel....the problem persists.
Not yet, I guess almost everyones situation is unique.
It can be a weak battery, old starter, leaking fuel injectors, fuel pressure regulator , vacuum leak, bad grounds etc...
If you look at my previous post I found the Crank sensor connection with corrosion and after cleaning it up that fixed it for me, However I have not been able to look at the one on my TL because of bad weather out here.
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
